Toshiba SD-P1200 Portable DVD Player Logo
lyn fraser Posted on Jul 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer screen is upsidedown what can i do to reverse it to normall
Anonymous
Level 3:
  • Toshiba Master 32,281 Answers
  • Posted on Jul 04, 2012
Anonymous
Toshiba Master
Level 3:
Answers
32281
Questions
Helped
7908135
Points
102259
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key.Restore by pressing Ctrl-Alt plus the up arrow key.ALSOTo change the display from portrait to landscapePress Ctrl-Alt plus a left or right arrow key.Some computers do not have this function.
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Fix screen its upsidedown
Hi There,
Pressing the key combination CTRL+ALT+UP or CTRL+ALT+DOWN will change your screen back to it's normal position.
You can also do this through the video manager control panel by right clicking on your desktop and selecting properties.
Samsung la32a450 and screen rotate up to down 180 degree
in the menu you can choose ,normal, upsidedown,or mirror.you have to chance that
We need to know how to fix the computer because the screen is upsidedown.
I think you will find that the rotation has been altered. Its a case of trying to get the mouse to goto the graphics icon in the task bar(Lower right, to the left of the clock) and altering it back. This will involve some trial and error with mouse movements as everything is reversed.
Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
The screen displays upsidedown
Try pressing and holding Ctrl, Alt and then any of the four arrow keys (Example:Ctrl-Alt-Down will rotate screen by 180 degrees)
Sincerely, CBR2009
7helpful
2answers
Inverted image
All images in astronomical telescopes are upside down and reversed-- this is normal. There is no up or down in space. Reversing the image just adds more GLASS to the light path.
Screen upsidedown
Hello agahan
My guess is that you have an Intel Extreme Graphics card in there. After doing some looking around, it looks like there is an adjustable option that will let you rotate the screen as needed, and there are 2 different ways to address it:
http://www.computing.net/answers/windows-2000/logon-screen-is-upsidedown/62429.html
From the Forum:
"To stop it happening again right-click on an empty area on the desktop, click on 'properties' then on the 'settings' tab followed by the 'Advanced' button. On here there is a tab relating to graphics, mine says 'Intel(R) Extreme Graphics' click on the tab then on the 'Graphics properties' button, choose the 'rotation' tab and remove the tick from the 'Enable Rotation' - remember to click 'apply'."
It is also noted that you can try Ctrl+Alt+Any Arrow to adjust the direction of your view. Check on both of those, and see if that helps.
~Cactus
Screen image is upsidedown
Hold down the CTRL+ALT keys, and hit the Up arrow on the keyboard.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
