Question about Acer Televison & Video
Today, when I turned it on, the Acer logo appeared and then the screen went all black with the exception of the name of a channel in the right upper corner. Then I tried the menu button on the remote control (thinking that, as usual, it had lost all the channels) but nothing happened: no button on the remote control (with new batteries) or on the side of the screen works, neither the on/off one! (I had to unplugged it to turn the tv off!) Any idea of what could it be?
SOURCE: Channel changing on PROSCAN 32LA25Q
I had the same problem, what fixed it for me was to set auto scan to setup all the channels for me again. Another thing to check would be whether it is set up to use CATV or AIR.
Posted on Dec 30, 2007
SOURCE: menu wont work, continuos channel search
Usually, this means that something has spilled into the front of the set and has contaminated the pushbuttons. If one of the channel pushbuttons has fluid in it, the set will just sit there searching for channels and will not respond to any other commands. The computer thinks you are pushing the channel button and responds accordingly. When you push another button the computer does nothing because it thinks that you are pressing 2 buttons at the same time. The board should be cleaned and any contaminated pushbuttons replaced by a qualified tech.
Posted on Aug 23, 2007
SOURCE: Channel Changing Problem
You have to go through the set up guide and reset the information you put in. It may have changed. Afterwards you must run through the auto program. This is a common problem i find with customers.
C-Dog
Posted on Feb 10, 2008
SOURCE: iLO LCD Color HDTV does not change channels / volumn...just turns on/off
You need a new control board for your tv...
Thank you
COmputerrep
Posted on Apr 29, 2008
This particular model of tv has a problem with the control board.
This is a common problem with this unit. You can find control boards on EBay, or through a local technician. Please refer to our online technician list for a professional near you.
Good luck :)
Posted on Jun 20, 2008
May 24, 2013 | Sylvania LD320SSX LCD TV
Nov 03, 2012 | Vizio VO47L 47 in. LCD TV
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Jun 01, 2012 | Samsung Televison & Video
Apr 09, 2012 | RCA Televison & Video
Mar 11, 2012 | Acer Computers & Internet
Mar 02, 2012 | LG 26LE5300 26 in. LCD HDTV
Feb 14, 2012 | Initial DTV-201 20 in. LCD Television
Jan 16, 2012 | Vizio VA26L 26 in. LCD HDTV
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
120 people viewed this question
