Question about 3Com NBX 3102 IP Phone
How to reset a 3com phone - 3Com NBX 3102 IP Phone
Posted by Shavannie Carter on
NBX_Tech
    New Friend:
  • 58 Answers
You'd have to reboot the phone, and press the white dot 'Program' button within 30 seconds of reboot, then use the arrows to scroll down through the menus to Advanced settings, and find Eeprom reset to default, and choose that. *Note- This will reset all values of the phone. If it's Ethernet Only, it's fine. If the phone is using a Static IP, it will also clear the IP addressing on the phone*
If you are talking about resetting the phone from a user profile perspective it is different. You can reset the voicemail password under the system maintinence, password administration and select user password in the drop down box. After the password has been reset (to the extension number) they can log in and change the recordings and password. You will also need to then go to the users tab and change the name.
Posted on Oct 21, 2013
How do i reset voicemail password on 3com 3120 phone?
On 5.0 and older software, Log into the NBX Phone system as administrator and click on "tab to it". Then click on the "security" tab under System Configuration. Click on "Reset User Password". Highlight the user you want to reset and then click "reset. The system will reset the password to the same as the extension number.
On 6.0 and later software, Log into the Phone system and go to "System Maintenance, Password Administration". Select "User Password" in the drop down menu and click "Go". Select the box on the left for the extension you want to reset and click on the "Reset Password" button at the top of the list. The system will reset the password to the same as the extension
Hope that helps!
Aug 02, 2014 | 3Com NBX 3102 IP Phone
3COM 3100 entry phone, how to configure SIP
From Digium Mailing List:
3Com 3100 series phones do not support SIP with non-3Com systems. They have a basic boot loader which must download code from a 3Com NBX or a 3Com VCX system. If you don't have either of these, then you won't get runtime code on the phone, thereby making it impossible to use the thing with Asterisk.
Asterisk Users 3Com Phones
Mar 14, 2014 | 3Com Computers & Internet
Reset 3com 3102
Hi Chirag,
On the web interface, use
1 Click System Maintenance > Purge Data.
2 Click Purge Database
This ll do fact reset.
HTH
-Karthik.
Oct 02, 2012 | 3Com NBX 3102 IP Phone
3com superstack 3 switch 3300 reset himself randomaly need a solution
take it to the 4s garage, if you want to find out the problem by yourself,you first have some professional tool , there are some diagnostic that always can figure out the problem i can show you: www.xcardiag.com/
Apr 12, 2012 | 3Com SuperStack Computers & Internet
3com AP 7250 - how do i reset it to factory defaults if i don't have the admin password ?
It will have a reset button on it, hold it down for ten seconds and it should reset the router to factory.
Mar 12, 2012 | 3Com Wireless LAN Access Point 7250...
I get the message: 3Com Model 3102- Wait for NCP M We have never seen this before and it is after a power outage. Our server is running. What is NCP?
Hello.
NCP stands for Network Call Processor. There is a problem with communication. Since your server is running, reset your router (disconnect power, wait a few minutes, then reconnect) that supports your IP phone.
Hope this helps.
Aug 29, 2011 | 3Com NBX 3102 IP Phone
How can I reset a VoIP Phone 3Com 3107c. The problem is: VoIP Phone is connected to the network, but when you press Talk Key, phone screen just show "Aquiring Link" 8 Times, after show "NO...
You are getting that message because the base isn't being seen by the system. It is either not plugged in or needs to be rebooted/power cycled. Check for both power as well as the network connection.
Feb 18, 2011 | 3Com 3107C IP Wireless Phone
3com 3crwdr100a-72 how do I reset the router
For 3com type of routers, you must connect firstly to 3com setup, By:
First: open your browser and type 192.168.1.1
Second: you will find adapter setting and reset it, it all depends upon your router's software.
Third: the easiest way is to reset it from the small button in the back of your router.
Dec 14, 2009 | 3Com Wireless LAN Access Point 7250...
3Com NBX 3102 IP Phone Logo
1,115 people viewed this question
Top 3Com Computers & Internet Experts
Mike
Vincent G
Vincent G
Sheldon Dedek
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
