Question about Acer Extensa 5420-5687 Notebook
Acer 5420-5687 wireless connection drops - Acer Extensa 5420-5687 Notebook
Posted by starlifter99 on
teflon282000
    Problem Solver:
  • 6 Answers
I think it depends on how far you are from your router. i was told by at&t that you need to be with in 20 to 25 feet to get a good signal. if that do not solve your problem. then i think you should go into your control panel, then to network and internet, then to manage wireless networks. delete all the networks you see. when you are done close out everything then look at the bottom right of the screen, you will see the internet bars for internet access. click on that. you should see your internet info. just reconnect.
other than that, i dont know what to tell you.
Posted on Oct 24, 2012
1 Related Answer
byteguy
Art Ellison
  • 2229 Answers
SOURCE: Acer drop internet connection, not locating
You haven't provided us with much information, but I'd suggest a couple of things:
Check to see if your wireless adapter in the computer is turned on or off. Some computers have a little switch on the front or side that turns the wireless on. If on, somewhere on the computer there should be a small light lit up indicating that the wireless is on.
If there is no switch, then the wireless adapter may be turned on or off by a keyboard combo of the Fn key plus one of the special function keys. That particular key will have a little icon that resembles an antenna on it.
If you are unable to solve the problem by using the switch, try to do a system restore back to when it was working.
Posted on Oct 01, 2011
Don't know how to connect to my home wifi
Connecting your Acer laptop to your home wireless network is fairly simple.
Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position.
Not all models have this switch.
Open the Windows Start menu and select "Connect To."
A list of available connections will appear.
Select "All" from the drop-down menu to view all available networks and connections within range.
Select the desired network and click "Connect."
Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Mar 11, 2014 | Acer TravelMate 2480-2779 Notebook
HOW DO I SWICH THE WIFI ON
Which model acer ???...
Aug 13, 2013 | Acer Computers & Internet
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
Acer drop internet connection, not locating wireless connections Acer problems with wireless connections
Sep 29, 2011 | Acer Aspire 5100 Notebook
Acer extensa 4620 Since purchased, wirelss
Try turning off your Acer wireless control and use "Wireless Zero Configuration"
Nov 27, 2009 | Acer Extensa 4620 Notebook
ACER 5720 WIRELESS CONNECTION PROBLEMS
Are you using security?
If you are try changing between wep, and wpa
If that still does not work use mac filtering
May 27, 2009 | Acer Aspire 5100 Notebook
Dropped Wireless connection on Aspire One 8.9" Netbook
make sure your isp is suppling your 2nd ip address...
Dec 25, 2008 | Acer Aspire One Netbook 8.9" Notebook
Sounds like a bad router or antenna. Try replacing the antenna or checking the connection of the antenna on the router. Have your ISP replace the router and the problem should go away.
Jul 30, 2008 | Acer Aspire 3050-1733 Notebook
Fios Wireless Drops
internal wireless is a hassle and does that on many models.
get an external pc wireless card and the issue will disappear.
you can run with both at the same time.
it fixed my issue for same system.
Jun 04, 2008 | Acer Aspire 5100 Notebook
Wireless connection lost
948c84d.gif Make sure #4 is switched to the ON position.
Then, double click on the wireless indicator located on your taskbar, near the clock in the lower right hand corner of your screen. That will tell you if it "sees" any wireless connections available to it.
You can download the manual for this laptop here: http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/a9b67d2003ba6822482571f8000f317e/$FILE/AS5680_5630_3690-ENG-OLM_0727.pdf
Let me know if this helps.
Apr 06, 2008 | Computers & Internet
Acer Extensa 5420-5687 Notebook Logo
48 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
