Zapco Reference 750 Car Audio Amplifier Logo
Gene Santos Posted on Jul 03, 2012
Zapco amp power light blinking - Zapco Reference 750 Car Audio Amplifier
If my zapco amps break down will the company repair them for free
Only if its under warranty. If you are the original owner with a reciept from an authorized dealer then they will warranty it for free. You can find information here---> www.zapco.com/support.html
I installed a 400 watt zapco competition amp\ front speakers play ...back woofers don't?
are you sure you didnt wire the amplifier the front and rear to
left/ right?
check your deck settings to see that the rear speaker rca are connected.
check all wires are connected.
push the mono or bridge buttons are off.
provide more info.
Install my amp
Go to this link and see page 47
http://www.zapco.com/files/Download/DCRef.pdf
How many rms does my amp have.....??????
4-channel, 4 ohms: 4 x 50 Watts
4-channel, 2 ohms: 4 x 90Watts
Stereo, 4 ohms: 2 x 180 Watts
T.H.D. : Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Dimensions: 13"L x 9.9"W x 2.25"H
Zapco I450 Zapco I 450 iForce Series 4 Ch. 360 Watt Amplifier
I have a zapco refrence 750.2 has no sound output when bridged but works fine when i run a speaker to each channel. any ideas on whats wrong?
check your settings on your stereo and the amp make sure you have changed to 1 ohm on the amlifier for a briged connection to a subwoofer and change from lpf to hpf on the amp there should be a switch.
...storing noise detected from my
Storing as in Distortion? If that's the case lower the output gain from your amp until it is suitable to you ears. It might be all the way open, besides this should be adjusted system to system.
Zapco DC Reference 750.2 problem
If the amp uses TIP35Cs and TIP36Cs, those will be the output transistors. Measure the resistance between legs 2 and 3 for each of the output transistors. Do any read near 0 ohms?
If you're new to repairing amps. The following page should help.
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
2helpful
2answers
Zapco 18 band eq
You will need to call the manufacturer, ZAPCO - 209-577-4268, or email them at tech support [email protected] , in order to purchase the part you are missing. It is possibel to hard wire the RCA parts you need and creat a homemade fix, but in all honesty it is not worth it, and it will probably introduce a lot of interference in to the quality of your signal path rendering it a bad option. Give them a call / email. If they will only sell the part to a dealer, call Car Depot @ 615 - 269-8080 and they can have the part purchased and delivered to you for a small fee. Good luck.
ZAPCO 9.0
Go here first http://www.zapco.com/ Good Luck
Top Zapco Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
