Can I plug in a C1000S mike into a Sony WM-DC6?
Can I plug in a C1000S AKG Microphone into a Sony Walkman WM-DC6? The C1000S has an impedance of 200 ohms.
Posted by Bob Mark on
Eliezer Pennywhistler
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
Sure. You need a cable or adapter that fits the mic's canon plug into the recorder's mic jack.
Buy one at Radio Shack, or Amazon, or eBay, or Full Compass - http://www.fullcompass.com/category/1-4-To-XLR-Adapters-Transformer-Type.html .
Posted on Nov 12, 2012
5 Related Answers
Anonymous
SOURCE: Sony Walkman WM-D6C
If your WM-D6C has a serial number below 267201 (take out the battery block and you'll see the serial number sticker there) then the problem is electronic, not mechanical. It is likely due to the speed controller chip (labeled as IC601 on the circuit board), which is made by Sony and is type CX20084. This chip decides the voltage that is fed to the motor which is only about 2.4 volts, Should the chip be defective then the motor receives about twice this voltage and thus runs too fast. If you take the back off the recorder you will see the circuit board; it looks like a rectangle with a small square extra bit sticking out to the right. It is here that the IC601 resides. It is about the size of a small pinky finger nail and has 8 tiny legs down each side. Measure the voltage on pin 15 (put one voltmeter probe (+) on the second leg down on the right side (pin 15) and the other one (-) on the battery negative), it should read about 4.8 volts, which it feeds into the base of transistor (Q601) that in turn will then feed 2.4 volts to the motor (if everything is working OK). If the chip is damaged, then the voltage on pin 15 will be close to zero, and the transistor Q601 will not be "held back" and so will feed about 5 volts to the motor. CX20084 is (unfortunately) obsolete, someone in the UK sells them for about $50, but an excellent company in Hong Kong (utsource.net) sells them for $5 (plus $8 S&H). Taking out the old chip and putting in a new one is close to microsurgery, you will need a micro soldering iron (18Watt Antex), a good eye, a powerful magnifying glass and a steady hand, but it can be done - I've done it! There is a possible second reason that could cause the motor to run too fast. There is a pick up coil on the main flywheel called FG901. If this is damaged it will be open circuit and then the only use for your recorder is probably a paper weight. You can test this by going back to chip IC601 and locating pin 1 (top left pin; a small circle on the body of the chip is next to pin 1), Pin 1 is connected to the positive side of a capacitor,  C602 (0.47 microF), check the resistance from the negative side of C602 to the ground (take battery out, and use battery (-) as ground). You should get about 600 - 650 ohms reading. If you get nothing, sorry there is not much you can do about it as these pick up coils are definitely not available. Finally, chip 601 (CX20084) goes bad if you connect the batteries back to front. Good luck. Giles..
Posted on Jan 16, 2009
Anonymous
  • 59 Answers
SOURCE: my sony walkman
Hello aga2958,
I think you need to visit maintenance center to fix that cause its hardware problem.
But you can check somethings before u visit them .. like:
1. If you are using Batteries to power up the Walkman .. be sure the batteries are full charged.
2. Try to power on the Walkman by Adapter 3 Volts.
3. Be sure the tapes you are using are fine into other Cassette.
Thanks for using FixYa.
Posted on Apr 26, 2009
caroldon
  • 17130 Answers
SOURCE: I have a sony walkman WM-3. It suddenly stopped
Please check for the belts if the battery you have installed is new and the set gives a hum on play. If not you will have to check the power switch, the mechanism switch and the line to the main board.
If the motor turns but not the capstan and the reel then change the belt, the rollers or the pulley. I hope this will get your set back to action. Good day
Posted on Jul 21, 2010
caroldon
  • 17130 Answers
SOURCE: how to replace the drive belt on the sony walkman
Since this is a very small player what is important is to be very careful and delicate to open the rear cover and do the repair. The printed circuit board has to be removed and moved up carefully not to damage or detach wires. Now remove the capstan cap and take out the old belt, check the size with the new one and if OK run in the same direction you had taken out. replace the lid and the pcb carefully and fix the wires according to the same pattern so as not to touch the belt and drives. Now put in a cassette and test. If it works ok with the speed close the rear cover. clean the headd, the rollers and the transport section . Now your tape has been serviced and must work well. Hope my advice helps you . Good day
Posted on Jul 22, 2010
rigger094
  • 188 Answers
SOURCE: how do I dismantle a sony wm-ex39 walkman. I
i had this problem.i use a knife to pry it open
Posted on Oct 17, 2010
C1000s hum/buzz on phantom power
possibly the microphone needs more power than your sound card can supply although I cannot imagine as the duet is a good piece of equipment.
Is the duet USB bus powered?
Have you tried another cable? Possibly one wire is defective which means that phantom power will superpose the audio signal. In this case you might hear a hum. By the way this results in 6dB of signal loss. This is why XLR plugs have 3 wires. If connected with a 1/4" jack it has to be a stereo plug (tip, ring, sleeve)
Mar 26, 2014 | AKG Audio Players & Recorders
My C1000S won't completely turn off ...I think it needs a new switch...what do I do ?
Where exactly do you hear the microphone "working"?
Are you powering it with a battery or with phantom power? What does your LED indicator light say?
The nature of an ON/OFF switch is that it is either on or off, so that does not sound like your problem. Theoretically, it could be dirty, so you can run some contact cleaner in the switch.
Apr 01, 2013 | AKG C1000S Twin Pack Professional...
My AKG C1000S shows a weak signal from one side of the two stereo channels when I use an XLR going to a 1/4 inch Stereo jack. Does the mic only work properly with a Mono jack?
You have connected the mic improperly. You'll need an XLR to 1/4" transformer to properly match the impedance, then run into a mono channel.
Mar 15, 2012 | AKG C1000S Professional Microphone
Barely has any output. i thought it was low battery but it was not. what could the problem be?
If this is a (phantom) mic, it has to be plugged into a phantom plug on a mixer (round black thing with 3 metal posts in the middle. Darren Kelly-themasterofthrowdown@yahoo.com
Apr 28, 2011 | AKG C1000S Professional Microphone
Hi, I'm trying to fit the polar pattern converter to my C1000S mic. I've removed the wire mesh part to reveal the shock mount and capsule but there seems to be a black plastic bit of a different shape...
Alan, the C1000s comes with 2 filters, and it sounds like one of them is already on the capsule. Yes you can remove the one already on. I find by gently twisting and pulling it comes off easily. The capsule is rubber mounted so it can take a little bit of pressure.
Feb 27, 2011 | AKG C1000S Professional Microphone
I have three working AKG C1000S. They all need grills. Who can I trust to service or sell grills?
AKG sells the replacement screen and tube assembly direct from AKG Acoustics, U.S.
+1 818-920-3237
[email protected]
They are expensive, $80.00 each.
Oct 25, 2010 | AKG C1000S Professional Microphone
How to disassemble it to fix connector
On the side near the connector you find a small screw.
Just loosin it and you can pull the connector out of the housing.
Here you can find a service manual.
http://www.akg.com/mediendatenbank2/psfile/datei/39/C1000s4055d1ee2167f.pdf
Regards,
Gerard
Jan 16, 2010 | AKG C1000S Professional Microphone
Akg c1000s replacement grille
Maybe you could find a local music store that repairs equipment to replace the grill. Sometimes you can find parts on websites like Ebay.
Oct 07, 2009 | AKG C1000S Professional Microphone
Microphone cuts out
If you tried other cords and other PAs the problem might be in the jack where the cord plugs into the mike. [email protected] might also be able to give you more info.
May 18, 2009 | AKG Perception 200 Microphone
95 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
