I accidently dropped my rolex onto tiled floor and a few hours later i realised that it had stopped ticking!!! WHAT CAN I DO??
Its time for a service.
Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
Posted on Feb 11, 2018
SOURCE: My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Posted on Jan 10, 2010
SOURCE: My Elgin Steel PQS Chrongraph is not working. The
If the problem started immediately after you dropped it, then the impact is likely to have damaged it and a trip top the dealer is unavoidable.
Whatever the cause of your problem it is best left to watch repairer to sort it out.
Posted on Feb 10, 2010
SOURCE: I dropped the watch on a tile floor. Shattered the...
Take your watch to any jewelry store and they will be able to order the crystal plus install it. J.
Posted on May 25, 2010
SOURCE: My rolex datejust watch has
mcdevito75 here, The answer is no, Rolex watches do not operate with a battery. Most Rolex watches are Automatic winding with the motion of your wrist / arm. Of course if you leave your Rolex on the dresser for say 30 hours, it will run down, simply hold the watch in your hand and with a gentle rocking motion say from 6--to 12 O'Clock for about 30 seconds, this will give your automatic Rolex an initial wind up, from there you just wear the watch and it will continealy wind itself. You may also have the non automatic Rolex in which case you would have to wind it dailey. If your Rolex will not run at all no matter what you try, Check out the repair service directory here at fixya, bottom of the page click on repair service directory then watches.
Posted on Aug 01, 2010
Testimonial: "Thank you for the quick response! I will try the advise you have given. you guys are awesome! i'm so impressed with your prompt response~"
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
Oct 08, 2012 | Rolex Watches
Sep 16, 2010 | Rolex Watches
Aug 01, 2010 | Watches
Jul 06, 2010 | Rolex Daytona 116520 Wrist Watch
Jul 10, 2010 | Chase 18.5mm-29.5mm PRECISION ROLEX OYSTER...
May 20, 2010 | Freestyle Shark Mako Watch Black Ion...
Feb 10, 2010 | Watches
Sep 20, 2008 | Rolex Explorer II 16570 Wrist Watch
Dec 09, 2018 | Rolex Watches
Sep 07, 2018 | Rolex Watches
Feb 19, 2018 | Rolex Watches
1,001 people viewed this question
