Toshiba 50HP66 50 in. Plasma Television Logo
Bev Neighbour Posted on Jul 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba Regza 32AV615DB
AV channel keeps changing
Level 3:
Top Expert:
  • Toshiba Master 76,851 Answers
  • Posted on Jul 03, 2012
Toshiba Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15262119
Points
237766
There is a input selection switching IC at the input section circuit. It t damaged. Seek experienced service tech: assistance.
5 Related Answers
Anonymous
  • 73 Answers
  • Posted on Nov 04, 2009
SOURCE: have 52 inch toshiba regza tv black box appeared
Check to see if the tv is in the text mode of the closed captioning.If not you may need a new main signal board.Also try unplugging the set for a couple of hours to reset it.
Anonymous
  • Posted on Jul 17, 2009
SOURCE: when i turn my toshiba regza on I cannot access
Try either the "content / menu" button between the volume and programme buttons. Failing that, when the tv has been powered up from the wall socket wait untill you hear a small click from the t.v (usually about 5 or so seconds after it has been switched on) before switching it on from the remote control, have no idea why this works but the dtv has worked for me ever since I powered the tv up like that
Anonymous
  • 362 Answers
  • Posted on Dec 14, 2007
SOURCE: toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
dave1645
Dave Naylor
  • 834 Answers
  • Posted on Dec 02, 2009
SOURCE: How do I retune a Toshiba Regza 32AV615DB 32-inch
what are you trying to do ?
if your trying to re scan your channels then go into youe setuo menu and rescan channels in cable mode if your on cable or antenna select air
adnanbhatti
Adnan Bhatti
  • 1188 Answers
  • Posted on May 01, 2010
SOURCE: Looking for an Instruction Manual for a Toshiba
I found an online version while searching. Its in PDF format 990 KB in size. Click here to open it. You can print it if you wish. Note: Don't worry if your TV's name isn't written. This manual is for the AV61 series so the complete model isn't listed.
1helpful
Toshiba 32av615db tv - keeps scrolling channels
On the back of the TV, where the main board is (the one with many AV inputs to it) there are several cables going into it.
Find the one that leads to the buttons on the TV - it won't be too hard to trace - and after turning on the TV disconnect that cable.
Or, if the cables for the buttons and the front LED and IR sensor are separate (sometimes they are) you disconnect the one for the buttons and then turn the TV on with the remote.
Either way, see if the problem persists with the buttons panel disconnected.
if it does then the problem is in the main board and likely you'll want it replaced. The way they make them these days it's really cheaper to replace the whole thing than to look for a problem among components the largest of which is about a millimeter long.
if the problem is in the button/cable connector...you'll probably find it easy. Often it's because that same cable has been trapped between the front and back covers and broken or shorted by the friction and pressure.
Hope this helps....would appreciate a review on Google if it does!
bobby
www.coppelltvrepair.com
My toshiba regza will not change channels, it just keeps saying
Its memory IC has damaged. Replace it with samey number.
Purchased Toshiba Regza 32AV615DB December 2010. On several intermittent occasions sound disappears and continuous buzzing noise takes over. Picture still on screen. Only way to rectify is turn TV off...
Sound carrier frequency are quartz locked in all modern TV. Your TV's sound freq: seems to be drifting. In the station tuning setup it will ask you Region ( Country ) Have you chosen correctly ?.
3helpful
Looking for an Instruction Manual for a Toshiba Regza TV 32AV615DB (32av61). Can anyone advise me where I can get one from.
I just bought my Toshiba 32inch Regza and I don't know how to connect my dvd! What channel does it play on? I'm in the dark..... I read the instructions but am still confused.
On the back of television you will find three slots, two of which are for plugging in dvd. PROBABLY it may be red and yellow in color. Just attach the cords there and press the av/tv mode or anything similar from your remote. It will switch to a separate channel where you can use the player.
How do I remove the stand from a Toshiba TV 19DV616DB
Mine isn't exactly the same model (I've a Toshiba Regza 32AV615DB) but on mine there are 4 small black screws at the back of the TV, near the lower edge. They're recessed into channels and quite difficult to see. Remove these 4 screws and you can lift the TV off the stand. Good luck.
1helpful
How do I retune a Toshiba Regza 32AV615DB 32-inch when I select retore defaults nothing happens
1helpful
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
