Question about Apple iPhone4 4G iPhone 4
Dropped Iphone, now callers cant hear me....
Dropped my Iphone hard yesterday ~ said no SIM installed afterwards... hubby was able to fix that problem. The phone charges, plays music, goes online ~ everything is fine except that now when I call someone I can hear them, but they can barely hear me. Maybe the speaker is busted? How can I fix this? THANKS!!!
Posted by amydivin on
Xiong Julie
    Habit-Forming:
    New Friend:
  • 81 Answers
Send it to repair shop, if you need phone repair tools, you can choose Vip Fix Shop Team. Professional grade Phone Repair Tools for iPhone iPad Cell Phone One Stop...
Posted on Dec 18, 2017
JPJP
    New Friend:
  • 3 Answers
Check the hole inside the headphone jack. It can get clogged with lint over time and either make a bad connection if you are using headphones, or remain partially pressed from inserting headphones. Use a small paper clip to gently loosen any debris.
Posted on Dec 17, 2017
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: My iPhone isn't charging.
pls go to phoneshop and buy new chager it work for u
Posted on Apr 23, 2008
Anonymous
SOURCE: iphone on/off button Jammed
Did the same thing. Used an x-acto knife to pry my button out. Works fine now, just not as pretty as before!
Posted on Jun 27, 2008
CaptDP
  • 133 Answers
SOURCE: iphone 3g stuck in emergency calls only
Are you using at&t. if not it was jailbroken and unlocked and that went away after you updated it.
Posted on Aug 11, 2009
Anonymous
  • 3 Answers
SOURCE: Dropped my iphone 3G, screen went black with some
It just happened to my this afternoon. My iphone dropped out of my pants pocket to the ground. The front lcd of the iphone hit the ground and it when blank/black. My iphone happened just like what you've described. I got my fixed. I opened it up and found the connector of the lcd was loose. I securely reconnected it and voila!!!! It works again like a charm! Goodluck to you all who has the same problem.
Posted on Dec 24, 2009
Anonymous
  • 502 Answers
SOURCE: Wet iphone working but white screen
Sorry but your lcd needs replacement. There are also free iPhone Repair guide that show you how to fix it yourself. The part is on Ebay.
Posted on Jul 10, 2010
Iphone 4 hearing problem
I paid $199 in the past for an exchange. The Apple Store is really good. If they can fix it easily they usually will for free. Back up your phone on Itunes before you take it in though, just in-case they need to reset your phone for you.
Blown speaker type noise with iphone reciever
I have seen this before three or four times on the i-phone. Your earpiece is broken and needs to be replaced. The firmware is not going to change anything. Bring it to at&t and they will flip it or repair it for you under warranty. If that is not an option, take it to any other service center that is qualified and certified, and they should be able to do it in like 45 min time while you wait. If you cant find anywhere to do it check my profile and we can help you out. Hope this helps.
1helpful
Iphone 5 can't hear callers but the hear me, speaker phone works
I have written up a useful guide on how to fix the iphone 6 can't hear caller problem iPhone 6 Can Hear Caller Fix
THE MIC IS NOT WORKING PROPERLY ON MY IPHONE. CALLERS CANT HEAR ME. HOW DO I FIX IT?
HI, that means the mouth piece is bad..All you need do is to change it.
cheers.
1helpful
Cannot hear any callers of imcoming calls from my iPhone 3G
Removed SIM card, sync iPhone with iTunes. Reinstalled SIM card and resynced again. Incoming calls can now be heard.
5helpful
Iphone 3g stuck in emergency calls only
In phone mode i can hear the caller but the caller can not hear me. Works ok in bluetoother or speaker mode.
Reseat the SIM card:
To remove the SIM card, insert the end of a small paper clip into the hole on the SIM tray.
Insert the SIM card using the same method.
Note: For best results, use the SIM card included with iPhone.
Then try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
2answers
Can only use speakerphone to hear caller's voice on my iPhone
It's usually caused by a defective or dislodged electronic module that sits behind the ear speaker, this should be covered under warranty unless there are visible marks of the drop. If you're not covered, you can try a iphone repair guide websites, there are also places that sell iphone parts.
Dropped cell and people cant hear me
I had the same problem as the person in the original posting -- I dropped my phone after which callers could no longer here me.  So I tried dropping the phone again, as the original poster suggested, and afterwards the problem was solved.
1helpful
2answers
Dropped phone to many times and........
I am also using motorolla v3 razer, when I dial a number, I can't hear any sound or ring, but they can receive my call. If someone call me, the phone ring, but when I answered it, I can't hear the caller. I have check the volume setting and call setting. What I did was reseat the phone components. Turn it off, and then remove and return the battery, memory card, and the sim card. It fixed the issue. I hope this can fix the issue you have.
Apple iPhone4 4G iPhone 4 Logo
Top Apple Cell Phones Experts
Ekse
ADMIN Canada
ADMIN Canada
Oloyede Monsuru
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
