My iriver is several years old and has several problems. A while ago it gave up letting my charge in by the AC powers connection.
It now does not load properly. It used to cut out and then show a 'low' battery sign when I try to reboot. Now when I try to boot the player it will either show the low battery sign or it will load and say I have zero files and zero songs.
If I connect to the computer it still shows all my files and music.
Can anyone help?
Sounds like the battery is dead. Rechargeables only last so long. I'd copy all the content off it, before the battery dies totally, which could make it not work even connected to your computer. Looks like you can get a replacement battery: Iriver h340 Google Search
And here's a video on replacing the battery: How to Replace the iRiver H340 Battery
SOURCE: Iriver H340 - battery
Visit http://xushi.co.uk/index.php?title=revive_your_iriver_h320_h340_with_a_new_&more=1&c=1&tb=1&pb=1 to see how its done. Buy battery from link to ebay
SOURCE: iRiver H340 new battery won't hold a charge!!
It can be the charger that is actually causing your battery to not hold a charge. The closest thing to you would be www.iriverstore.com. connie
SOURCE: Iriver H340 motherboard?
Hi , the price of the motherboard you might as well buy a newe Iriver mate , but if you wanted you might be able to salvage one from a broken I river on an auction site since replacements are not readily avalible for the public .. and as for complexity ,
it shouldnt be too hard but technician to preform the repair job would save alot of hastle in the long run.
SOURCE: iRiver H340 firmware
with the hex file hold the navi button for a few seconds; you get four options select the general one then you will see an upgrade firmware option. select this the hex file on your player is your firmware it will then go through the upgrade process. don't touch while this is happening. it will turn off when done. then thats it. Be careful the version v1.30 will get rid of the video option go with v1.29 or less
SOURCE: iriver h340 - new battery charges but does not work when not in electicity
They may need to be on the other way.
