Lexmark T620 Laser Printer Logo
Posted on Jul 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black lines on printed page
Sometimes 3/4 of the sheet is totally black
  • Official Brand Answer 3,344 Answers
  • Posted on Sep 06, 2012
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923226
Points
5508
Please refer to the link below. It should contain all the details for the Lexmark T620 printing in black. Should your require further details, please feel free to contact us on [email protected].
Link: http://bit.ly/OqGFRz
2 Related Answers
Anonymous
  • 837 Answers
  • Posted on Nov 23, 2008
SOURCE: 3 colored lines along page edge each time I print
try doing another alignment page ...
fotomohamed
mohamed salim shaikh
  • 321 Answers
  • Posted on Jun 18, 2009
SOURCE: black stains on the printed sheet
use deep head clean
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Replaced black ink cartridge, but now it only prints a very faint line, cant make out what is printing
Sir/Madam
If your printed pages have a horizontal line in the text or graphics (as shown in the illustration below) or blank text, some of the nozzles may be clogged and need to be cleaned
Go to Section 2 for instructions on how to print the Alignment Check sheet and adjust the print alignment.
Section 1: Checking the print quality and cleaning the print head
  1. Print a Print Quality Check Sheet.
    1. Press Menu.
    2. Press the UP OR DOWN ARROW key or the dial pad to choose Ink Management and press OK.
    3. Press the UP OR DOWN ARROW key or the dial pad to choose Test Print and press OK.
    4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and pressOK.
    5. Press Color (Colour) Start. The machine begins printing the Print Quality Check Sheet.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  3. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing from one or more color blocks:
  1. The display will then ask you if the print quality is OK for black. Press the DOWN ARROW key or 2 to choose Nofor black with the problem.
  2. The display will then ask you if the print quality is OK for Color. Press the DOWN ARROW key or 2 to chooseNo for color with the problem.
  3. The display will then show Start Cleaning? Yes No.
    Press the UP ARROW key or 1 to choose Yes and the machine will start cleaning the color ink cartridges.
  4. When the machine completes cleaning the print head, press Color (Colour) Start. Another Print Quality Check Sheet will print.
  5. Repeat the cleaning and the quality check process following the Step 4-7.
  6. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
9. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times). If you do not see any further improvement after that, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times). If you still do not see any improvement, please contact Brother Customer Service from "Contact Us."
10. Press Stop/Exit.
Section 2: Checking the Print Alignment
  1. Press Menu.
  4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and press OK.
  5. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  6. By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
  7. Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the UP ARROW key or 1 to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the DOWN ARROW key to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
  8. Press Stop/Exit.
If the print quality continues to be poor, go to Section 1 to clean the print head.
If your question was not answered, please check...
Improve poor print quality Brother
Or
If You Still need Brother Printer Help then I suggest You follow Us On For: Brother Printer Support
1helpful
My printer will not print. I recently changed ink cartridges and I'm getting a message suggesting that I realign something. How do I do that?
Most all-in-ones require you to scan an alignment sheet after changing the ink. Make sure the printer is on. Press Menu then use the up and down arrows to navigate to Maintenance. Click OK. Navigate to Auto Head Align and press OK. Select Yes and press OK. Load a sheet of Letter or A4 sized plain white paper in the rear tray, follow the on-screen directions. Open the output tray gently and the output tray extension. Press OK. When the page prints out, do not touch the printed sections. You should see a set of broken lines on the page, among other printing. The first section of columns will have 2 black, 1 blue and 3 black. The next row has 4 columns (blue and pink (to my eye)); the final row is 3 blue and 3 pink. If this prints okay, then select Yes and press OK. Next place the printed page face down on the glass of the scanner unit so that the black triangle at the top left of the page is in the left back corner of the glass. (The triangle is an alignment mark and lines up with the alignment mark on the edge of the scanner unit.) Close the document cover and press OK. The sheet will be scanned and the print heads will be adjusted. Do not open the document cover or move the sheet until the unit has completed the adjustment. Afterwards you can discard the sheet.
If the unit fails to adjust the print head, it will indicate this in the LCD screen. In that case, try manually adjusting the print head from the Canon Toolbox on your computer. If you can't get the printhead to align properly manually, the unit may need service.
For pictures, see the manual or support for the all-in-one here: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp490#ServiceAndSupport . If you use the Support option, search for align print head.
I hope this helps.
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
When printing the sheet of paper has 3 dots on the
Yes this could be the drum.
You could remove the drum and carefully look for the pattern of dots etc that you are getting on the page but on the drum surface.
I would suggest replacing the drum 1st and retrying.
If the black lines are just down one edge then the fuser could be to blame for the black marks but without being able to see the page i cant tell. The drum is certainly my 1st suspect and is easy for you to try.
If you are in Berkshire try www.repairmyprinter.co.uk for additional help
Black lines on printed material
check the optics section the remove the exposure glass anh clean the fisrt,second, and third mirror
3helpful
Counter info print out
Hi Beadworker,
This information can be found by printing a configuration page from your printer. Follow these steps to print out a configuration page.
Printing a Configuration Page
You can print a configuration page from the printer’s control
panel. Use the configuration page to view the current settings,
to help troubleshoot problems, or to verify the installation of
optional accessories, such as memory or an optional tray.
To print a configuration page:
1 In ready mode, press the Menu button on the control
panel until you see “Information” on the bottom line of the
display.
2 Press the Enter button to access the menu.
3 Press the Enter button when “Configuration” displays
on the bottom line.
A configuration page prints out.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
