Question about Stanley Garden
How to put belt back on stanley hydro automatic tractor 17.5 hp
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Posted on Apr 22, 2009
Anonymous
  • 95 Answers
SOURCE: I have a 20 hp craftsman lawn( hydro gear
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Posted on Jul 31, 2009
Anonymous
  • 437 Answers
SOURCE: i need the belt diagram for a 42
Do a model search on www.partsdirect.com. This is the website for Sears equipment. Just reminder you will need the model number from under the seat to help you find the right model.
Posted on Sep 25, 2009
Anonymous
  • 11 Answers
SOURCE: Problem with the Husqvarna Lawn
http://weborder.husqvarna.com/order_static/doc/usa/2009/I09000/I0902011.pdf
Posted on Sep 06, 2010
Anthony Browning
  • 640 Answers
SOURCE: What length belt do I
You can find the model number under the seat by the battery. With that number you can go get the belt at a local lawn mower repair parts shop. And with that number you can find the routing on an illustrated parts drawing by going to a lawn mower/ small engine repair parts website such as partstree.com or outdoordistributors.com. If you can not find it I can tell you, but I would like to glance at the drawing to see if the deck is the one that I am familiar with, so I would need you to send me the model number from the tag.
I hope this helps you get it done.
Posted on Aug 09, 2011
Howto troub le shoot transmion o a troy bilt tractor
well is it a hydro or not
if its a hydro suspect a bad trans
if its belt driven unit suspect bad belts
next time put this in lawn mowers
Sep 07, 2014 | Cars & Trucks
Hydrostatic want pull hill
Either the belt is slipping in the pulleys ( replace belt ) or the hydro unit has internal wear, if this is the case as the unit gets hotter the issue will become worse due to the oil getting thinner and leaking internally, this would mean a hydro rebuild, or replacement unit
Jul 07, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have Craftsman 42" lawn tractor with the automatic transmission. It runs fine but it is not pulling a grade now. The belt seems tight, what could be the problem?
As you attempt the incline grab the clutch pedal with your heel and pull it towards you if it starts pulling correctly you have a belt problem . If it makes no difference you are having hydro pump problems
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman lt 2000 I was mowing and put the brake on to pick up a stick, i never left the seat just bent over, then when I put it in forward (hydro stat) the tractor would not go anywhere, I check...
the brake mechanism is likely stuck, if you pull the hydro release rod and attempt to push the mower it should free wheel reasonably well, if it continues dragging then the brake shoes are likely seized, even though the arm may be free
Jun 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My riding mower start but it wont move
Is it a Hydro, or belt drive?
Is Hydro on bypass?
Is the belt off, or broken?
May 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman model # 917.274031 garden tractor.
check the rear wheels,has you fixed a flat and not put a key back in or not fitted the wheel correctly.
Some hydro ?? cut out levers only have a spring to pull it back and get stuck.
Dec 08, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Hydro.tran.
have you changed the drive belt since new? also check tension pulley for drive belt, if ok and belt is in good condition, you have a bad drive.
Sep 24, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
