Question about Sony Cyber-shot DSC-W70 Digital Camera
The pictures I take inside are either blurry or dark yellow in color.
I cannot take a decent picture with this camera inside. I find all the options totally confusing.
Posted by lovebassets on
5 Related Answers
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: pictures are blurry blue/white colour with vertical lines
You camera has problem with CCD Imager.
Following Sony Official weblink might help you to get Free of Cost repair of DSC-T1 camera with problem in CCD Imager.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Posted on Aug 05, 2008
propdoc
Ernel Elkin
  • 3 Answers
SOURCE: blurry pictures
Check to see what the setting is for Image Size (I have sony cybershot DSC-w50). On the camera itself, it is the button on the bottom. My camera was on the 8"x10" size and I was getting blurry shots (especially with people in them). I switched it to the 4x6 print size and it seems to be much clearer.
Posted on Dec 01, 2008
Anonymous
  • 66 Answers
SOURCE: Camera vibrates when it is turned on therefore pictures are blurry
seems the motorised lens of your Sony have issue.
should get it rectified without delay if still in warranty.
contact the vendor and sony support.
Posted on May 30, 2009
bhargav
  • 66 Answers
SOURCE: pictures still blurry
Instead of green auto mode set to P mode and chagne the flash setting to non auto.If flash is is in auto mode flash will not fire and picture will be blurry.So your flash must fire every time (and it must not be decided by camera's auto flash mode).
I am sure this will solve your settings.
Please rate if satisfied.
Posted on Apr 01, 2010
AdiIngel
Adi Ingel
  • 87 Answers
SOURCE: shaking and blurry pictures
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on May 26, 2010
Mitsubishi WS-65809 Iris problem
i KNOW THIS SET WELL and it has no such option.
I am not sure if you really want an answer as you post this repeatedly and do not respond to comments.
picture is very dark and blurry?
Mar 30, 2012 | Mitsubishi WS-65809 65" Rear Projection...
The !AE error messsage and a yellow !camera image appears on the camera screen and pictures are horribly blurry. How can this be fixed?
if this is a slr camera ensure the lens is fitted correctly or that the connectors on the lens and body of camera are clean.
also try changing setting out of AE "apature priority" to another setting such as auto, the indication could mean that the place where the photo is being taken is too dark and that the apature setting for the speed set is too small for a decent image. and the apatures needs to be open further or the shutter speed needs to be slower or the IOS/ASA needs to be raised. to stop bluring at slower shutter speeds or in dark areas it is advised to use a tripod or other sability device.
I hope this was useful.
Jan 24, 2011 | Cameras
Blurry pics or with yellow tinge
If your pictures are blurry, you have a shutter speed that is too slow. If they are yellow, your white balance isn't set to auto. Try using the camera in more light or setting it to full auto. There is most likely nothing wrong with your camera.
Jul 19, 2010 | Nikon COOLPIX P90 Digital Camera
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Sep 23, 2009 | Canon PowerShot A630 Digital Camera
My screen shows a blurry picture and it takes a blurry picture. it didnt used to. what is wrong? how do i fix it?
I have the exact same problem. When I was in NY last fall, suddenly my camera would only take blurry pictures. I hadn't changed any settings or anything. I can get halfway decent pictures in Auto mode, but any of the other settings only take blurry pictures. Apparently a lot of people have this problem, but no one knows how to solve it...
Feb 28, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Blurry pictures
try turning of the stabilizer if you have one it will be in the settings menu
Jan 08, 2009 | Canon PowerShot SD1000 Digital Camera
Blurry pictures
Both of these problems are caused by underexposure. There are several causes for this. If you are set in AUTO MODE check the shutter speed and lens opening in the view finder. If the speed is less than 100 and the shutter is less than 5 and you are not using flash. You will probably get blured and dark pictures.  Practice shooting with your settings outside in sunlight , inside with lamplight, inside with flash and all of the above with motion. Check the exposure after each shot and make adjustments. In a short time you will get very good at setting your camera.
Dec 09, 2008 | Nikon D70s Digital Camera
Pictures have brown instead of color look, why
You have a bad film pack. Replacing the film pack with a new one should fix the problem. Nothing in the camera can change the color of a picture. The camera can over expose pictures (wash out the picture), under expose pictures (dark pictures), or the picture can be out of focus (blurry).
Nov 16, 2008 | Polaroid One600 Pro Instant Camera
Blurry or dark pictures in low light
Low light= slow shutter speed = camera shake
Use a tripod
Nov 04, 2007 | Kodak EasyShare Z740 Digital Camera
Digital camera
normally that happen in the cameras when we take out one filter that is fitted between the CCD and the Lens, maybe on that camera is just donĀ“t exist and depending on the light the image changes.
Jan 22, 2007 | Sakar 89379 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
