The brightness (and other power inverter issues) has always been flaky on this unit. [Too bad its not nearly as reliable as my 17 year old Hitachi CRT!] So I'm opening it up so that I can check voltages when the backlighting is dim. [Lately it only gets to normal brightness after more than 4 hours - or when I start to dismantle it.] I've figured out how to remove the bezel from around the monitor, but this does me no good unless I figure out how to remove the base. Any suggestions?
SOURCE: monitor isn't working
just replacing the fuse should help. There are two of them on the inverter board. depending on which one is blown will give you 2 different issues. One will cause the screen to flash content perfectly for two seconds and then drop out. the other will be really dark if can see any picture at all,
SOURCE: No Power, But I can't open the plastic case
Hi Andrew,
Try to study of how to open it from this web site .
www.lcdrepair.us will be very helpfull to you.
Have a try
TIA
SOURCE: Hitachi 19" CRT monitor display twitches and shrinks when hot
Sorry Jamess02, the problem at this point is bad solder connections. The snapping you are hearing are sparks jumping the gap. If this is not fixed soon, there will be permanent damage done that will not be worth the repair. Any shop can fix this ion about 10 minutes. Simply open up the unit and resolder any connections that appear grainy or have rings. Please note that there are dangerous high voltages present even with the unit unplugged that can cause injury.
Dan
SOURCE: always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
SOURCE: How do I open a Viewsonic VX900 monitor? Monitor
Hard to explain but these pictures may help: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
Nevermind. Just need to slide off the hinge bolt caps.
There is a very nice service manual here:http://www.go-gddq.com/upload/2011-07/11...
