My washing machine is about 2 years old and has started leaking water from underneath. It's not coming from the pipes at the back and only seem to leak at the end or near the end of the cycle. There isn't loads of water but it's enough! Thanks
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
SOURCE: Water leaks from inside of machine
TAWS850PQ0 WITH SAME ISSUE...found it to be the water pump located bottom front of machine...looking for replacement now...
SOURCE: Bosch nexxt washer is leaking from underneath
All the things that greendude said plus check the seams inside the drum as if these have even slightly parted it could cause the leak you're describing. Good luck.
SOURCE: LG Tromm WM0642HW washer leaking water!
I also had water leaking from under the washer during rinse cycle only. I tilted the washer back far enough to get under it and found that the drain hose, part # 4738ER1002 had been punctured by my wifes bra underwire. Super easy to replace and the part is only about $18.00 on ebay.
