MY SHARP COPIER AR-M201 SYSTEM ERROR (F2-04) that is why? can you help me
SOURCE: System error (f2-04) for model #AR 168S
f2 codes all have to do with the drum. have you replced the drum lately?
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
- Toner supply abnormality caused by
installation of unpacked toner cartridge
