My clothes come out of the washing machine with black greasy marks
SOURCE: Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
SOURCE: black oil or grease on clothes after washing
is you machine a top loader or front loader? if its a front loader the black marks could be from the boot. WIpe the boot with a good cleaner. and try not to over load machine. and if it a top loader your transmission is probably leaking oil back into clothes tub. You could have it rebuilt $$$ or better replace the machine.
SOURCE: mildew smell coming out of washing & black marks on rubber lining
Hello,Not sure I can solve this but according to repair services ,HC or HE washers especially front loaders need to have the tub cleaned once a month ( at least) with bleach or a product that can be purchased at Lowes or any other appliance store. Your problem according to those I have spoken with is Mold in the system. We have bleached ours and used two of these pellets and still are having a problem. I was told that since it is the first time in a year of having this machine that it will take some more cleanings. Hope this helps. By the way we have a Frigidaire front loader.
Al
SOURCE: black marks
To eliminate possible bearing failure, spin the drum by hand and see if u can detect any rumbling noise or strange nioses coming from the drum, if u can then it is probably grease that is coming from the bearings. The other possible cause is an effect called ****, this is a result of washing at too low a temp, this causes a build up of dirt and grease,leading to the sort of prob that u are experiencing The thing u should do is to put the washer on at a high temp with powder in but no washing and do a full wash . This is called a maintenance wash, and should be done at least three or times a year depending on how often u wash more frequently if u do a lot of washing. Clean the door glass and rubber seal as thoroughly as u can ,and remove as much sludge and dirt as poss. This should help with your prob. Plz rate my solution. Thanks.
SOURCE: Black marks on clothes after washing
Try running a few caps of CLR in the washer (without clothes, of course!) Then run a few cycles with no additives. I've heard that powdered lemonade works also. Might be safer to try first. Good Luck!
Hello Loree Grudem - This can be the result of the shaft bearing and seal. They may have become worn and the transmission oil is creeping up to get in your water. Once this happens, it gets on your clothes to cause staining. Or possibly you have a buildup of fabric softener that comes loose and puts a greasy like substance in your water and on your clothing. Once you put your clothes in the dryer and the old fabric softener melts you will see these spots. I suggest contacting a professional to move forward accurately.
