I understand that the lower panel on the front nearside of my vehicle is not blocked in behind the small bars that go across to the centre panel is this correct as I am led to believe it is to allow air into the air con system.
Well, I don't know. I would have to see the car.
Generally, as long as air can flow thru the condenser and radiator, the ac system can produce cold air.
As for the interior, you normally pull in outside air and cool or heat it, but you can also recirculate inside air which would close off the outside fresh air intake for the cabin.
SOURCE: 1997 audi A4 heater blowing cold air
You will have to change the heater core. 9 out of 10 times, when the heater is not heating the air, it is a bad heater core.
SOURCE: 99.5 A4 Quattro Air con wont turn off
On some Audi's there is an ECON button which you must press for up to 5 seconds to turn the AC off.
SOURCE: 2005 Audi A4, heater is blowing cold air
Recently had the same problem with my Audi A4, it was the engine thermostat needed replacing, now working fine
SOURCE: Audi A4 2004. Vent is centre of windscreen seems
flap motor that controls the screen vent needs replacing
SOURCE: Audi A3 2tdi 2005 - hot air, cold air and air con not working -
You may need to reset basic settings for the control module using a scan tool , reading the logged faults stored in the control module is needeed also .
