Question about HP Computers & Internet
The task bar disapeared - HP Computers & Internet
Posted by dan nicholas on
Brian Sullivan
  • HP Master
  • 27,725 Answers
Run you antivirus program
If CTRL+ESC didn't make it come back, then the program that displays the task bar most likely isn't running.
That program is often called the "Windows Shell", but it's really "explorer.exe". It's the program that not only displays the Taskbar, but also responds to the CTRL+ESC sequence.
The workaround: press CTRL+ALT+DEL to fire up the Task Manager. Now on the File menu, select New Task (Run...). Type in "explorer" and press OK. That should restart explorer and re-display your Taskbar.
hope this helps
Posted on Jul 02, 2012
Tray app missing
What Tray app? What OS? In the Tray Notification Area? Open Task Manager, find "explorer.exe, click on it and End Process, all you desktop will disapear, click on File in the top left of Task Manager, open New Task (Run...), in Create New Task, type exprorer and OK. Your Tray Notification Area will reset.
Jan 31, 2013 | HP Pavilion Computers & Internet
The taskbar disapeared
Press CTRL+ESC. If your Taskbar magically reappears, then it's probably simply been resized too small, repositioned somewhere you didn't expect it, or perhaps it's beneath another application that's running full-screen on your computer.
The workaround? Press CTRL+ESC to access the Taskbar.
hope this helps
Jul 01, 2012 | HP Pavilion Computers & Internet
How to get the task bar to it natural size?
It is possible to make the task bar taller than it is by default, and this is the only way that I know of to change the size of the task bar, so I have to assume that you are asking how to take the task bar back down to the original "tallness." You would put your mouse cursor at the top of the task bar until it turns into a double-headed arrow, and then click down and drag the top edge toward the bottom of the screen until it is the normal height. If the task bar is locked, this cannot be done, so make sure it is unlocked by right-clicking on an empty spot on the task bar and make sure that "lock task bar" is not checked first.
Jun 10, 2011 | Microsoft Windows XP Professional Full...
Sidebar has suddenly moved to side affecting size of screen. How do I return it to bottom???
You are probably talking about the windows Task bar that normally resides at the bottom of the screen:
Two ways of moving this task ba, to top/bottom/letft/right position of the display:
  1. Move the cursor on a blank/inactive area on the task bar, usually in the largest blank area towards the right, click and hold the right mouse button and drag the Task bar to the bottom of the screen.
  2. Go to the Task Bar 'Properties' (You can get this context menu by clicking the left mouse button after putting the cursor on a blank/inactive area on the task bar) and change the 'Task bar location on screen' option.
Hope it helps: let me know how you go.
Dec 17, 2010 | Toshiba Computers & Internet
My icons and task bars dissapeared!!
Hackers got mine too. I am waiting for a response as well. If one is sent to me I will send you the material as printed out for repairs
Jul 17, 2010 | HP Compaq Presario SR1132CU (PE558AR) PC...
Loaded DVO on Vista and it will not open to screen
What do I do if Cook'n won't open or it has disapeared?
  1. First you should check to see if Cook'n is being minimized to the bottom of your screen. If it is simply right click on it and choose "Maximize" or "Restore"
  2. If it is not in the tool bar at the bottom of your screen then we need to go into the "Task Manager"
  3. To get into the "Task Manager" hold Alt+Ctrl+Delete all at the same time (if you have vista you will have to then select task manager)
  4. Look under the "Applications" tab and see if you can see Cook'n running. If it is running right click on it and choose either "Maximize", "Restore", or "Bring to front"
  5. If Cook'n Opens then you can close out of the "Task Manger" and close out of Cook'n
  6. Then Right click on the icon of Cook'n (strawberry) and choose properties. Then 2/3 the way down it will say run "normal window" you should change that to "run maximized" then click OK
  7. You can then try to open Cook'n Again and it should open just fine. If you continue to have problems please email [email protected]
Nov 09, 2009 | DVO Enterprises Cook'n Deluxe 6.0 Full...
Home Screen Problem
Try reloading explorer.
To do this press Ctrl, Alt + Del, select task manager, when task manager opens up click on the processes tab and look down the list for explorer.exe, highlight that and click on end task, the desktop will disapear but don't worry about that. In the task manager window click on file, from the list select new task (run) and type in the box explorer and click ok. The desktop will return and try using a short cut.
If the shortcuts still won't work you could have a virus or malware on the computer.
If this is the case please post back with which operating system you are using.
Good luck.
Aug 20, 2009 | Toshiba Satellite A105 Notebook
Microsoft publisher 2003 logo and navigation bar disapear
I am having a simular problem, but it seems it is with ie 8. As long as I use ie 7 or firefox, I don't have the problem. You might try going to tools and the options and web tab and then make sure to take the check mark out of the "rely on VML for faster graphics downloading" and take the check out of "allow PNG as a graphics format to improve graphics quality"
Jul 04, 2009 | Microsoft MS Publisher 2003 w/ Digital...
Virtual PC will not open
If you have Windows 7, 'native' Virtual PC will only be available and functional, regardless of the icon on task bar, if you have: 1) Windows 7 Professional or Ultimate 2) Hardware Virtualization 3) Your PC/Laptop BIOS has support for hardware Virtualization and you have enabled it. If you have all the above pre-requesite, I suggest that you re-download XP Mode and VPC from Microsoft site. If you do not meet the above requirements, you can always install a (free) alternate such as Microsoft VPC 2007 SP1 or better still (e.g. has USB support) VirtualBox. Hope it helps. Let me know how you go.
Jun 05, 2009 | Microsoft Virtual PC for PC
Tool bar missing on computer
Assuming "tool bar" = Task bar
and your OS = XP
It's possible your task bar is hidden on bottom
just drag the bottom line of your screen upward
Check if your task bar properties are set to "hide the task bar" remove the setting
Jan 05, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
170 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
