Black screen , comes up with bd wise in corner no picture
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
SOURCE: Problem w/Samsung BD-P1200 Blue Ray Disk Player
Hello mljackson197,
This indicates a problem with the pickup head. First I would suggest cleaning the laser head with a disk made for that purpose. If this does not work, then I would suggest (if you have a background in electronics) taking the cover off and checking the bias voltages on the laser pick head (comparring them to the schematic values). What I believe is happening is just a dust problem, however if it is a circuitry problem, contact the manufacture or use the schematic/service manual to locat OEM parts.
I would, however try to clean the pickup head first.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: DVD player keeps turning off and on the T.V.!
there is a button that you can choose tv dvd cd vcr select tv
SOURCE: Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
