Cleaner stands on nose and won't move
SOURCE: Polaris 380 stand on nose while on will not move to wheels on gro
First, check to confirm that the blue restrictor disk is installed in the UWF to decrease water flow. It sounds like you are getting too much water pressure. You could also install the red restrictor disk to decrease water flow even more. If this does not work, verify the back-up valve is cycling. Hold the valve out of the water and watch the jet. It should come on and go off. Make sure that your thrust jets are working properly and are positioned correctly. Also, try removing the head float and shaking it. If there is water in the float, you will want to get a new one. Finally, check the hose floats to make sure they are
spaced evenly. One of these soultions should make your pool cleaner function properly. If you need additional help, please let me know.
Posted on May 20, 2010
SOURCE: Polaris 380 stand on nose while on will not move off
There are several things that you can check on these automatic pool cleaners to try and correct this problem. First, make sure that the filter bag is not full. A weighed down bad can cause the cleaner to tip onto the nose. If there is water in the head float, you will need to replace it. Make sure your hose floats are spaced correctly so that they are not causing the cleaner to float incorrectly.
Posted on Jul 28, 2010
SOURCE: I hooked up a new Polaris 280 pool cleaner to
I would first take it out of the water and check for proper wheel RPM. If it is less than 28 RPM or you are getting no movement at all, it is going to be a problem with the power source. It is likely going to be that your booster pump is missing, malfunctioning, or is not installed properly on the pool cleaner. There are a few other things to check. Clean the skimmer, filter and pump basket, clearing any debris that restricts water flow. Check the hoses, connections and swivels for leaks. Try removing the blue restrictor disk from the UWF or if an adjustable gate valve is installed on the booster pump or cleaner line, open it completely so water can flow freely.
Posted on Jul 21, 2011
May 21, 2017 | Braun Shavers Male Pulsonic System 9595CC...
Nov 19, 2011 | Dyson DC14 All Floors Upright Vacuum...
Oct 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Oct 20, 2017 | Horizon Fitness T82 Treadmill
Jul 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Here is the basic idea on how to keep the
refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved
by an electric fan or blower in order for that product to work properly. If air
movement is blocked the fridge won't get cold, the central air conditioner
won't cool enough, the vacume cleaner won't clean as well. Check on your
fridge's air movement by inspecting the bottom of the fridge for dust and cob
webs. Remove the front bottom clip-on plastic grill. Or also even access the
lower back of the fridge by removeing
the screws holding up the heavy cardboard cover to see inside. Blockage
of air flow will prevent a fridge from getting cold. Just like a vacume
cleaner stops working when the bag is filled with dust and fibers.
The air could be blocked by the accumulation of dust and
fibers. Look under your fridge if it is
cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air
movement from back to front (or visa-versa) of your fridge will slowly (years)
prevent how good it cools. The build-up of dust and cobwebs prevents your
fridge from cooling (more specifically prevents the heat to disapate
from the metal heat disipating fins
attached to the metal tubes to be blown off by the fans air). OK! Remedy
for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE
CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge
manufacturers do not provide a dust filter like the vacume cleaner and central
air systems manufacturers do. You have to figger out
the best way you can clean it. Possibly vacuum with a crevice tool, or use
a small brush than vacuum. The extreme would be unplug
the fridge ( so you won't get electrocuted) bring
a water hose into the kitchen and spray water at cobweb buildup at the bottom
fridge, than wet vac the floor then wait
20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front
of your fridge and you hear the fridge electric motor turn on, the fan will
blow air.The fridge
May 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
of air flow will prevent a fridge from getting cold. Just like a vacuum
cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and
blow air out the bottom.The fridge
May 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
May 17, 2010 | Polaris 380 In Ground Pool Cleaner
2,434 people viewed this question
