Question about Dewalt DW411 quarter - sheet palm grip sander with dust collection
SOURCE: Where can I get instsructions for the Dewalt DW411
go to Dewaltservicenet.com and in the midle of the page and towards the bottom under need manual type in your model number and you should be able to download anbreakdown and operators manual
Posted on Oct 05, 2010
SOURCE: DW411 Can I put a velcro
Dewalt is not going to make an accessory for you to do so, since that sander was designed to use 1/4 sheet sandpaper, and therefore takes standard paper clamped in place. You could make your own base for the sander out of thin plywood or some other suitable material, covered perhaps with a laminate or rubber surface, that would accept PSA (pressure sensitive adhesive) sandpaper, which you can buy in rolls appropriately sized for your sander. Or you can try some kind of after-market conversion kit such as this one (See also here, etc.)
If you really want a hook and loop base on your sander, I recommend you bite the bullet and simply purchase a random orbital sander with a H&L pad. Then you'll of course have to buy the perforated paper discs to go with it....
But you'll easily be able to change grits, and the performance and quality of your sanding will improve.
You might check the reviews in various woodworking magazines before you make a purchase, just so you know what you're likely to get for your money. There's a vast array of machines made, and the quality varies accordingly, and depends to some extent on your budget and intended use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Dec 21, 2010
Feb 28, 2015 | Ridgid Makita 98462 9910 Belt Sander 120v...
May 24, 2014 | Dewalt DW411 quarter - sheet palm grip...
Dec 03, 2012 | Dewalt DW411 quarter - sheet palm grip...
Dec 20, 2010 | Dewalt DW411 quarter - sheet palm grip...
Oct 15, 2010 | Dewalt DW411 quarter - sheet palm grip...
Oct 06, 2010 | Brother MFC255CW All-in-One InkJet Printer
Oct 05, 2010 | Dewalt DW411 quarter - sheet palm grip...
Sep 23, 2010 | Dewalt DW411 quarter - sheet palm grip...
Mar 19, 2010 | Makita 9404 4'' x 24'' Belt Sander
Jul 12, 2008 | 2001 Mercury Grand Marquis
232 people viewed this question
