SOURCE: Title Rack will not turn with service or arrow buttons
It sounds as if you may have a problem with the mechanical element of the title rack.
Try to move it manually.
If it is moves easily the problem will more than likely be the motor or the Display Unit.
If that is the case you will need help from your Rowe Ami dealer.
Regards
Alan Hood
ami-man
SOURCE: Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
SOURCE: Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
SOURCE: spares ?fboxor the rowe cd 100 juke
have the motor replaced and the rotate switch just to be sure..
SOURCE: What is command 84 on Rowe Ami Jukebox
Command 084 relates to modem communications. This was intended for future use, 084 is Modem Is:
Regards
Alan Hood
ami-man
UK
