Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
I've had a paperwhite for 2 years without any problems. As soon as the low battery comes on I plug it in to recharge. Don't plug it in for just a few minutes, anytime you think it's getting low. Best thing is to charge any of todays electronics is to fully charge it and wait until it says low battery to recharge. Then charge it fully and continue the same way. Batteries last longer that way. As to where to get it and how to replace. Check Kindle user info or contact the help desk.
I assume you've tried holding in the power button for 30 seconds?
Leave your Kindle on until the battery dies and then recharge it.
Failing that, contact Amazon - they replaced mine immediately and without quibble.
To restart your Kindle 3, you will need to have it recharged first. Then, disconnect it from the computer or charger and slide the ON/OFF switch to the ON position and keep it there for 15 seconds and then release it. Kindle will reboot.
The Kindle 3 also has a hardware reset button inside, but you will need to open it, in case you do not manage to make it work with the solution provided above.
Hope you can reset your Kindle and have your books back!
Then it means files of the Kindle Operating system might be corrupted in the Device. You need to reinstall the operating system in the kindle support. You can ask for the Support Kindle Technical Support Registration 877 690 9305
You can charge it by using the cable that came with your Kindle (or another micro-USB to USB cable). Just plug the small connector into the bottom of your Kindle and the larger end into a USB port on your laptop while your laptop is on.
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Try to power up your Kindle with a
different battery. If that fails, you need a new logic board. Amazon should give you a replacement. If you're out of warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
