Question about Refrigerators
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the Bosch fridge compressor is still running none stop. Any solution?
Posted by James Wang on
ALI ONE
    Sergeant:
  • 195 Answers
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Posted on Jun 30, 2012
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: My whirlpool Refrigerator motor keeps running
Keep an eye on the running time and temparture of the refrigerator. It will need time to return to normal cooling temps since the defrost and hot temps inside will take maybe a few more hours to reach normal. If not, get back with me and I will go through a step by step process on eliminations,  If so I will need age of fridge, Make and Models Numbers, Thanks Sea Breeze
Posted on Oct 27, 2007
Anonymous
  • 362 Answers
SOURCE: fridge compressor runs continuously
make sure its cooling well it could be low on freon and causing it to run continually, it should be iced up if running and freon is not low.
Posted on Dec 27, 2007
farfield
Farley Redfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
Anonymous
  • 103 Answers
SOURCE: Fridge not getting cold Bosch KGV36390/05
Hi: It shouldn't need a recharge as your freezer is cold, and that's wher the fresh food section gets its cold from via a fan. If your vents are blocked with too much food in the freezer this will happen. If you have a problem with the defrost heater or timer frost will build and block the port to the fan, causing a warm fresh food section. If the circulating fan is out your f.f. section will get warm. It's a small fan not to be confused with the condenser fan below (at the grill.) Here's a question for you. Did the fresh food compartment work for the first week or two? That's how long it would take frost to build and jam the system if your defrost system is out. If this is the case you can unplug it and put your food in a cooler. Melt the frost with a hair dryer carefully avoiding plastic components. It will then work for a week or two before it fails again. It will get you buy until you get service. If you do it yourself... Look for the defrost heater in the freezer and see if the coil of wire in the glass tube is broken. You will need a service manuals or a parts list with a diagram. Sears parts on line has a good database of parts and diagrams. Hope this helped, Jeff
Posted on Jun 01, 2009
Redpackman
  • 24 Answers
SOURCE: amount of time the compressor and fan stay on
No, that's not too long. It takes a long time to bring the temp in there down from room temperature to around 38 degrees and zero degrees in the fridge and freezer, particularly with the smaller, energy efficient compressors we now have in most of our appliances.
Posted on Nov 08, 2009
Why doesn't the water inlet valve shut off completely?
http://www.repairclinic.com/PartDetail/b129p3/Bosch-Freezer-Water-Inlet-Valve/00649626/2000566?modelNumber=B26FT70SNS%2f04&ss=a3b129d1144601&mr=1
Sep 15, 2015 | Bosch B26FT70SNS
I cannot get face book newsfeed on my iPad.?
Facebook Customer Support:
Phone Number: 1-650-543-4800
Average Wait: 12 minutes - 24 hours, 7 days
Suggest trying a new browser like Firefox or Google Chrome
Nov 08, 2014 | Facebook Social Network
How to reset a filter display on a bosch refrigerator
from our bosch manual: press and hold the light/filter button for 3 seconds. the water symbol is reset. the symbol stops flashing. the new filter cartridge is activated.
Apr 16, 2014 | Bosch B26FT70SNS
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Apr 23, 2013 | Cars & Trucks
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 | Freezers
I have a servis fridge freezer m7873.yesterday morning the motor became very noisy.by late afternoon it stopped altogether,and everything began to thaw.what do you suggest?
that motor noise if it is the compressor is not a good sign. You will need a service tech to inspect it to make an educated decision on what to do next. I would replace the freezer if it would be cheaper than the repairs
Nov 24, 2009 | Freezers
Brought freezer yesterday and is not freezing
It is probably out of freon.
A/c compressor
It probably failed because it reached high temperatures or pressures. make sure the regular maintenance has been performed then wait 1 day and try again. It has internal overload protection and that can take hours to reset. If this doesn't work then you probably need a licensed technician to take a look at it.
Jun 07, 2008 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
john h
