Water Pump for 02 2002 Ford Focus Bosch Logo
Ben Kossa Posted on Jun 30, 2012
Ford focus 2002 antifreeze flows on the floor. Help please!
Ford focus 2002 water antifreeze flows on the floor. Help please!
  • Anonymous Mar 30, 2014
    Ford focus 2002
joelman198
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Jul 07, 2014
joelman198
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
3467
Points
14
If coolant is leaking inside the vehicle, then your heater core is leaking. The heater core is a radiator looking piece that is mounted in the HVAC box in the dash and it allows heat from the hot coolant inside and the blower fan blows air through it which pulls the heat from the heater core out through the vents. The heater core is really the only component inside the vehicle that has coolant in it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
251
Points
I believe that means you have a blow heater coil
2002 Ford Ranger pickup leaking on floor board on driver's side
You didn't say what was leaking, water or antifreeze. If it is water dripping, your drain tube from the AC evaporator compartment is blocked. Clear that and the condensation will drain outside the car. If it is antifreeze, your heater core has a leak and will need to be replaced.
Antifreeze leaking from engine on 2001 ford focus
It sounds like you have a blown head gasket, check your engine oil, take off your oil cap and if it is frothy around the cap and inside the head, you have a blown head gasket.
2answers
My a/c not working properly and water leaks onto the passanger floor mat. the box is cracked or broken water coming from their?
drain is not draining may be clogged look under car and with a small wire or pipe cleaner see if you can unclog it. Hope this helps tim
I'm leaking antifreeze around where my Water Pump is located when the engins off.
sounds like a water pump going out. There should be a weep hole on the water pump if it is leaking it is an indicator to replace it very soon.
2helpful
What type of antifreeze is used with a 2005 Ford Focus
Hello mk12x.
Ford specification is Motorcraft Premium Engine Coolant VC-4-A (in Oregon VC-5, in Canada CXC-10) or equivalent meeting Ford specification ESE-M97B44-A (green color) with a mix of 50-50 coolant and clean water.
I hope your repair goes well for you.
Kl
My 2002 mondeo ghia is overheating and the fan is not kicking in, aso have to fill water bottle at least twice a day
Have your belt(s) checked for tightness, have your water pump checked, replace the thermostat and ALWAYS keep enough antifreeze in the system to protect it to 20° below zero. It is also anti-boil.
1helpful
I have a ford focus se 2002
No it sounds like your water pump bearing has worn causing the leak.Change the water pump.
I just bought my ford focus used and at the time of purchase I did not see a hole in the passenger side and the next morning I seen water or something on the floor what is it?
it could be water from the a/c sometimes were the water is supose to drain out it gets covered with dirt. try that may work
Top Bosch Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Robert Swatek
Robert Swatek
Are you a Bosch Vehicle Part and Accessory Expert? Answer questions, earn points and help others
