Question about Acer Computers & Internet
When i boot acer with dvd it shows image checksum error
My computer name is acer aspire 5742 model i created a bootable dvd through image burner when burn process completes i booted it but it shows image checksum error
Posted by purushothama on
White Zombie
    Top Expert:
  • 4,961 Answers
Re burn a new copy... You probably just had a defective cd.
Posted on Jul 01, 2012
5 Related Answers
Jastababe
Terry Lynn Deschamps
  • 117 Answers
SOURCE: windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
How to make a bootable Windows Vista ISO DVD media
1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
3. Exit from the Install Windows screen.
4. Download CDimage 2.52
5. Extract CDimage from CDimage.zip to the C:\ root directory.
6. Open a command prompt shell, and run the following command:
cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK)
1. Complete step 1 - 3 as above.
2. In the command prompt window, run the following command:
oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
3. Burn the ISO image file by using last step above.
Posted on Mar 24, 2008
SOURCE: Bad image checksum and not reading a hard drive
The checksum is a long number that is computed. This sounds like maybe your cpu is bad or going bad. You don't provide enough information to determine a solution. So...
If you are trying to install Windows and you get this error, your memory may be bad (google for memtest86), your CPU may be bad, or your CD/DVD drive may be bad. Try the easiest first. Test your memory and change your CD/DVD drive.
If Windows is already installed, your memory or CPU is bad. Test your memory. If it's good, I would have to assume the CPU is bad.
Hope that helps.
Posted on May 07, 2008
Donald B Stoll
  • 597 Answers
SOURCE: acer aspire 2920z cannot boot hard disk drive
Well either way it's probably not a good thing. You've either lost critical files or damaged the boot sector of the drive. The question is do you have valuable files on that hard drive that you need? If the drive is going bad, the more you run it the less chance you have of retrieving those valuable files. If you know how you can put in the XP CD and boot off it and do some repair but DO NOT try to re-install Windows at this time as it may try to format your drive and then your valuable files will be gone. You should have some professional help to try to repair your current windows. The best way to solve this is to probably get another hard drive as they are pretty cheap. Exchange drives and re-install windows then get someone knowledgeable to retrieve your valuable files from the old hard drive then send it back to the manufacturer and see if you can get a new one on warranty and keep it for a spare or sell it.
Posted on Jun 01, 2009
Anonymous
  • 166 Answers
SOURCE: acronis loader fatal error- I can't boot up !
if your pc starts ok with no cd in than do it like that if you see this error all the time it means your hard drive is shot, or erased, or partially erased and needs to be setup again or replaced. got nothing to do with acronis if it does this all the time even with no cd in drive.
Posted on Aug 23, 2009
Anonymous
  • 17 Answers
SOURCE: How to reset your lost windows password using a CD/DVD or usb fla
As far as I know there a are a lot of ways to solve your problem and the easiest one of them is to use program designed to see to such problem!
And I have tried many of them, according to my experience, I recommend you the password recovery bundle which not only can recovery your windows password but also other files' password.
And I google the address for you. it is http://www.recoverlostpassword.com/products/passwordrecovery.html
Wish you good luck.
Posted on Jan 29, 2010
How to burn a dban dvd for a acer aspire one?
IT should be an iso file right. Get imgburn it's free and burns iso's properly. You just click Write image file to disk and browse to the folder containing the iso.
Or in Nero burning you have to select Burn Image from the Recorder menu. If you just burn the iso to a disk thats all you will get.
When you burn an iso properly it extracts all the files in the iso as it burns it, including any boot info it needs to be bootable.
Feb 10, 2012 | Acer Aspire Computers & Internet
My aspire 5742 burns dvd but not audio music cds.it spins it and burns it but nothings written on the cd
OK when you boot up your computer does it says your DVD so so is working
if is not back up your drive in the BIOS or get a soft ware call or download from CNET call covert dvd and musics.....
Sep 21, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
This could be your HDD, failed. Work through, the troubleshooting procedures.
Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 14, 2010 | Acer Aspire 4315 Notebook
How do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
reinstall applications and drivers.
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
Dec 20, 2009 | Acer Aspire 5720 Notebook
Error: 0XC000000C; What's the solution?
My 0xc000000c problem seemed to result from disk surface damage on the restore DVD. I burned a new copy of the restore DVD and the restore then proceeded normally.
Using a DVD copy program that provides an aggressive read method to extract data from damaged disks might help you the most.
Nov 08, 2009 | Acer Aspire 5100 Notebook
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
  4. Download CDimage 2.52.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
Windows vista
Mar 24, 2008 | Computers & Internet
Writing bottable disk
Here are the instructions, taken right out of Nero's manual for Burning ROM 8. page 42:
9.3 Creating and Burning a Bootable Disc
To create a bootable disc, proceed as follows:
1. Click on the New button in the main Nero Burning ROM screen.
�� The New Compilation window is opened.
2. If you want to create a bootable CD, select the entry CD from the combo box and the entry
CD-ROM (Boot) from the list box. If you want to create a bootable DVD, select the entry
DVD from the combo box and the entry DVD-ROM (Boot) from the list box.
�� The tabs for the bootable disc are displayed; the Boot tab is in front.
3. If the template data for the bootable disc should originate from a logical drive:
1. Select the Bootable logical drive option button in the Source of boot image data area.
2. Select the entry you want from the drop-down menu.
If the logical drive you want does not appear in the drop-down menu, the reason for this is
that the drive is bigger than the space available on the disc. Please note that for operating
systems as of Microsoft® Windows® 2000 you need to have administrator rights in order to
be able to access drives directly, which you will need to do if you are to create bootable
discs.
4. If the template data for the bootable disc should originate from an image file:
1. Select the Image file option button in the Source of boot image data area.
2. Click on the Browse button and select the desired image file.
3. Select the language that should appear while the system is booting from the Boot locale
drop-down menu.
4. Check the Enable expert features box and select the emulation type for the image file
from the Emulation type drop-down menu.
5. Select any other options required on the tabs (see New Compilation Window).
6. Click on the New button.
�� The selection screen is displayed.
7. Select the files/folders that should be written to the ISO part of the bootable disc and drag
them into the compilation area.
�� The files/folders are displayed in the compilation area and the capacity bar indicates how
much storage space is required on the disc.
�� You have now created the bootable disc and can start the burn process (see Starting
the Burn Process).
Feb 06, 2008 | Computers & Internet
Computers & Internet Logo
125 people viewed this question
Ekse
Lee Hodgson
Lee Hodgson
Steve Sweetleaf
Steve Sweetleaf
