SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
SOURCE: Konica Minolta Bizhub 350, for faxing on Windows Vista PC
Yes you need the Driver.
http://help.bt.konicaminolta.ca
You can find all the drivers and help you need there.
