Question about Hayward Pool & Spa
Continue to get error message "prime failure". Checked above ground piping for leaks and did not detect any.
SOURCE: pool pump noisy
maybe plugged or restricted with something. try cleaning it and see if that will help.
Posted on Jun 06, 2009
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 03, 2009
SOURCE: hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Posted on Aug 06, 2009
SOURCE: Hayward Self-Priming Pump with AO Smith 1 HP 56J
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Posted on Nov 20, 2009
SOURCE: how do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
May 31, 2014 | Hayward Industrial Products Hayward...
Apr 21, 2014 | Hayward Industrial Products Hayward...
Oct 07, 2012 | Hayward Pool Products Hayward EcoStar...
Jul 23, 2012 | Hayward Pool & Spa
The most common causes of no prime are that the filter pot is not filled
with water (don't forget to put the cover with a gasket on), there is
an air leak in the pipes/valves between the pump and the pool, a plug of
leaves or other debris in the suction line, or the pump is installed so
high in elevation relative to the pool that just a little of the above
issues will prevent it from priming. I hope this helps.
If
this answer does not resolve your issue, please comment with additional information
before rating the answer. Positive feedback is especially appreciated once your
problem is solved! Thank you.
Aug 25, 2011 | Hayward SAND FILTER, PRO SERIES
May 29, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Nov 21, 2010 | Hayward Pool & Spa
Jun 07, 2009 | Hayward Pool Products Hayward Power Flo LX...
402 people viewed this question
