Following clearing a paper jam, printer won't initialize. Green and yellow lights continue to blink and screen says "Initializing..." It has been about 20 minutes so far. Not sure how to proceed.
SOURCE: Constant Initialization
on the main board ic3 and 2 you will see two fuses fu2 and 1 see which one is blown and replace the ic on next to it. it will work. rb..
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
?· Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
?· When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
?· When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
?· Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Hi
Error 5C10 means a paper jam or the printer has
encountered an internal error. And error 6A00 is
caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve
this issue. On the printer press and hold the ON/OFF button or unplug the power
cord. Wait for 10 seconds, press power button ON/OFF button again. If this
doesn't resolve the error code then unplug the printer for 10 minutes. Also,
inspect the back panel of the printer for any paper jams. To clear the paper
jams---
Turn off the printer and disconnect the power cord
and USB cable. Remove the jammed paper slowly using the following procedure.
Open the rear cover to check if the paper is jammed. Pull out the cassette and
check if the paper is jammed inside the cassette area. Stand the printer with
the rear side down, holding the document cover. Press the tabs together and
pull the green cover toward you. Check if the paper is jammed. (If you were not
doing Duplex printing, you do not have to follow this procedure.) Close the
green cover and place the printer back to a normal position. Reconnect the
power cord and power on the printer. Confirm the Alarm light is off. Load paper
back into the ASF or cassette. Press to clear the message and continue
printing. If you are printing from application software, follow the
instructions displayed on your computer. Hope this helps... Please post back if
you need more information.
Daniel
We would like to know more about the lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
Since the printer will print, for us to give the common light sequences, please provide us information which light is orange on the printer.
For further assistance, please call Lexmark Technical Support.
Top
Paper jams inside the printer
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
