SOURCE: incoming call number barring
I have been told this not possible on nokia 6300 without buying a package which I don't need as I will just ignore call from this particular caller.
Thanks any way for your help.
Regards,
Peter.
SOURCE: what is the incoming call barring password for
i think you need to look at this site.. i hope your problem would be solved..and you may get additional useful details about your cell phone which is very much valuable i suppose..just have a look..http://www.scribd.com/doc/299040/Nokia-Universal-codes-
SOURCE: what is incoming call barring password of nokia
to block incoming calls press *33*0000#. to unlock press #33*000#
SOURCE: my cell nokia 2700c has
Hi
Just Call to your network Customer Care (service Provider) they can provide you The password for your Call barring after that Just do one thing get into call settings go to call barrings & select Cancel all barrings.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
You can bar the calls that can be made
or received with the device (network
Make calls 35
© 2010 Nokia. All rights reserved.
service). To modify the settings, you
need the barring password from your
service provider. Call barring affects all
call types.
Select from the following voice call
barring settings:
Outgoing calls - Prevent making
voice calls with your device.
Incoming calls - Prevent incoming
calls.
International calls - Prevent calling
to foreign countries or regions.
Incoming calls when roaming
- Prevent incoming calls when outside
your home country.
International calls except to home
country - Prevent calls to foreign
countries or regions, but allow calls to
your home country.
To check the status of voice call barrings,
select the barring option and
Options > Check status.
To deactivate all voice call barrings,
select a barring option and Options >
Deactivate all barrings.
To change the password used for
barring voice, fax, and data calls, select
Options > Edit barring password.
Enter the current code, then the new
code twice. The barring password must
be four digits long. For details, contact
your service provider.
hope this helps
John
