When car is running put in reverse, it will roll back if on a hill. If on a level surface put in reverse, car will roll back about 2ft then stop. When I push the gas pedal car want move. But when push it will roll back while car is still in reverse and running. What seems to be the probably.
SOURCE: 2009 Toyota Corolla
1st, is your foot on the brake? That's a safety feature, u must depress the brake pedal before u can shift out of park.
SOURCE: 2007 toyota corolla stop accelerating, pushing gas
throttle position sensor needs to be changed
SOURCE: Gear question
Your should have it in drive, drive will always be in 1st gear when starting from a stop, if it roll to much you could have the idle check to make sure it's with in specs.Hope this was very helpful.
SOURCE: 2006 toyota corolla car starts but then stalls
change the fuel filter and make to clean the fuel inectors
