Need the location of defrost timer
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
SOURCE: hole in freezer of haier refrigerator
The refrigerant used since ~ 10 years is no more dangerous than the one previously used and it is even doubtful that the newer stuff is any better for the ozone layer.
The original coolant could be inhaled without injury as long as one didnt suffocate from a lack of oxygen.
The repair may not be cheap since it will entail the removal and replacement of the damaged coil.
This will require some specialized welding to install.
Using a normal table-top or floor-standing fan to circulate ambient air through the refrigerator with the door(s) open is a safe and fast method for defrosting units that do not automatically defrost.
Just make sure you have some absorbant material in the bottom to avoid water running out of the unit.
Poking the coils with sharp objects can result in the problem you now have or fracture hidden joints that will allow the gas to escape.
SOURCE: freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
