Trying to print and message comes up that printer is offline, paused and communication error. Have turned off, on, reconnected, nothing has worked.
SOURCE: printer not printing
try to reinstall drivers for printer and if not working reinstall software that came with it. u can also go to hp.com and download newest drivers for ur printer. also make sure wires are connected properly and that ur pc detects it.
SOURCE: Error while communicating with scanner message
Smile...well this is due to a default setting in windows which u need to change.
1. leave the device plugged to the USB & power it
2. Go to device manager \ expand (+) universal serial bus controllers
3. Right-click \ properties \ usb root hub \Power management tab \ uncheck box (allow the computer to switch off the device)
Restart! Don't forget to vote me dear!
SOURCE: i have a hp psc 1410 all in one printer and when i
Try this simple step first,
Disconnect the Power cord from the back of printer (while printer is on)
Wait for 10 seconds,
Connect the cord back and wait till it initializes.
Close HP Director or HP Solution Center,
Try to Scan, It should work.
A
quick fix for most communication errors can be achieved by resetting the printer
and/or rebooting the PC. Simply disconnect the printer from your computer.
Reboot your pc. Unplug and re-plug the printer into the power source to reset
it. When the printer turns on, reconnect it to your computer. Then try to print
again once the computer fully recognizes the USB connection.
If
that doesn't help, try the steps below:
1.
Disconnect the printer from your computer.
2.
Unplug and re-plug the printer into the power source to reset it.
2.
On your computer, go to Control Panel > Printers and Faxes.
3.
Delete the Lexmark print object.
4.
Reboot your pc.
5.
When your pc turns on, reconnect the printer.
6.
Wait until your pc fully recognizes the USB connection. To check, go to Control
Panel > Printers and Faxes. If you see a new Lexmark print object in the
list again, then try to print again.
You
may also try to update your printer driver by visiting the Lexmark website at .
Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
