Kenmore Elite 44173 30 in. Electric Cooktop Logo
Posted on Jun 29, 2012
Manual for cooktop 79042800502 - Kenmore Elite 44173 30 in. Electric Cooktop
Can I remove the downdraft equipment under my jennair electric cooktop and still use my cooktop?
It is possible to remove the downdraft equipment from underneath your JennAir electric cooktop and still use the cooktop, but it depends on how the downdraft equipment is attached to the cooktop and whether there are any other issues that may arise from removing it.
Before attempting to remove the downdraft equipment, you should consult the user manual or contact JennAir customer service to ensure that it is safe to do so and to obtain any specific instructions for your particular model.
Some potential issues to consider when removing the downdraft equipment include:
  1. Airflow: The downdraft equipment is designed to help draw smoke, steam, and odors down and out of the kitchen. Without it, you may experience reduced airflow and ventilation, which could result in lingering odors or smoke.
  2. Heat distribution: The downdraft equipment may also help distribute heat evenly across the cooktop surface. Without it, you may experience hot spots or uneven cooking.
  3. Stability: The downdraft equipment may provide additional support or stability to the cooktop. If it is removed, the cooktop may become less stable or secure.
If you decide to proceed with removing the downdraft equipment, it's important to follow all instructions carefully and to take appropriate safety precautions. You should also be prepared to address any issues that may arise as a result of the removal, such as by using an alternative ventilation system or adjusting your cooking techniques to compensate for any changes in heat distribution.
If you're unsure about whether or how to remove the downdraft equipment from your JennAir electric cooktop, it's best to consult with a professional technician or contact JennAir customer service for guidance.
Nov 29, 2022 • Cooktops
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Manual for bcg640nx cooktop gas
Do you mean the Blanco BCG640NX cooktop? Many of the Blanco manuals are available here: http://www.blanco-australia.com/Blanco-User-Manuals.html . Scroll down for the Cook top manuals. The direct link to the BCG640NX manual is http://www.blanco-australia.com/IgnitionSuiteVirtual/uploads/docs/BCG640.pdf . (Note the same manual applies for several Blanco models.)
I hope this helps.
Jan 20, 2012 • Cooktops
Missing manual and gas diffuser
May I get the make and model # to help you get the manual.
Also from the gas supply from house to cooktop it should go like this.
gas valve
gas line
regulator
then cooktop
I need an installation manual for a cvg4380p Jenn-Air cooktop
Hello Chuck,
Your request is for the Jenn-Air CVG-4280P gas cooktop installation instructions, even though the info at the top of the page states a JED8430 electric cooktop,
If I've got your request correct, here's a link to the installation instructions for the CVG-4280P cooktop.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380PII.pdf
If you'd also like the owner's manual for that same cooktop, here's the link for that too:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380P.pdf
Hope you find this Very Helpful and best regards!
Merry Christmas!
How do I get a service manual download for this cooktop?
See if you can find it here.
If not, I'll upload it to this site or email it to you.
http://www.dacor.com/Customer-Care/Manuals-And-Specs.aspx?TaxonomyId=149
1helpful
Frigidaire electric glass cooktop wiring problem
HEllo
I have the following manuals in PDF format,
I will gladly email them to you.
Model: GLEC30S8ESB Owner Guide(English): 318200612en Wiring Diagram: 318046807 Installation Instructions: 318201426 Parts Manual: 5995479655
Eddie Rentas
Tupper Lake NY
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
