Question about Hayward Pool & Spa
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
Posted on May 22, 2009
SOURCE: intex pool pump directions
from skimmer one hose goes into pump. outlet goes back to pool
Posted on Jun 16, 2009
SOURCE: my pool pump just quit running
Check the GFCI where the pump is plugged in to.
Posted on Aug 23, 2009
SOURCE: Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Posted on Apr 14, 2010
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
Jun 05, 2017 | Pool & Spa
Jun 01, 2013 | Hayward S166T Pool Filter System w1 HP...
Jul 12, 2011 | Hayward SAND FILTER, PRO SERIES
Jun 03, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
Jul 22, 2010 | Hayward SAND FILTER, PRO SERIES
Jun 19, 2010 | Hayward Pro Series 21" Above Ground Pool...
May 27, 2009 | Hayward SAND FILTER, PRO SERIES
42 people viewed this question
