Question about GE Refrigerators
I changed water filter on ge profile refridgerator now water doesn't dispense
Posted by C.D. Sturdy on
ALI ONE
    Sergeant:
  • 195 Answers
HI.HAVE U TURNED WATER ON? :) GOOD LUCK
Posted on Jun 29, 2012
5 Related Answers
Anonymous
SOURCE: I have a side by side GE profile Artica
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Posted on Mar 09, 2009
erpaalai
Eric Duda
  • 999 Answers
SOURCE: GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Posted on Jun 20, 2009
Anonymous
SOURCE: Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
Posted on Jul 22, 2009
acrman404a
  • 38 Answers
SOURCE: I have ge profile refrigerator tfx25pr with
THIS MODEL DOESN'T HAVE A FILTER
Posted on Nov 19, 2009
Anonymous
  • 311 Answers
SOURCE: ge profile arctica side by side- ice maker and
The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
Posted on Jan 11, 2010
GE Profile PSS26SGPA Water Dispenser won't stop dispensing water
water shutoff valve bad or dirty,could be minerals in your water
Nov 23, 2013 | GE Refrigerators
Ge Profile soap dispenser doen't fully open during wash
Pour boiling water into the dispenser, it may be gunked up with soap residue
Mar 21, 2017 | Dishwashers
Changed water filter in ge model gshf5kgxbb now dispenser doesn't work
With some of the GE refrigerators the air that is introduced into the water line keeps it from working until the air works it way out. IF you are sure you change the filter correctly, then just hold down the dispense button for a little time and then let off and then go do something else for 30 minutes or so and then hit the dispense button again. The ice maker will start working when you get the air out.
Jan 01, 2012 | GE F-150 Refrigerators
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
My water dispenser will not dispense water. I
you just need to defrost turn off fridg. over night it is frozen in the frezzer door
Feb 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refridgerator Not Dispensing Water
did the water work before you changed the filter . water when chilled may have frozen in line. . i would before major work adjust tempt of both freezer and frig . if too cold / forzen line .. are you freezing any thing in crispers. this is a good clue.. hope this might help .. mm
Dec 07, 2009 | Kitchen Ranges
No water, no ice, but new water filter cartridge
If it was running before the filter change you need to purge the filter cartridge of the air in the lines. Also check voltage on the back on the water control valves . While someone presses dispenser you should get 120volts AC on the plug receptacle side for the dispenser . Let me know what you find, Sea Breeze
May 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
245 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
