Cars & Trucks Logo
Denise Adkins Posted on Jun 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Truck will be running fine, then all of a sudden it will completely shut off. After we wait a few minutes and pump the clutch and make sure it is all the way to the floor it will start, sometimes. S
Truck will be running fine, then all of a sudden it will completely shut off. After we wait a few minutes and pump the clutch and make sure it is all the way to the floor it will start, sometimes. Sometimes we have to wait till the next day. It has also just lost power almost completely and then when I gave it gas it kept running.
Alex Shol
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 31, 2020
Alex Shol
Contributor
Level 1:
Answers
Questions
0
Helped
1797
Points
11
We want to recommend you our website https://ottofact.com/
Our service helps people to find the best low-interest financing and leasing offers.
All our clients get a discount.
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on Jun 28, 2012
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29057657
Points
266281
You need the engine computer scanned for fault codes, i thank you have an ignition control problem like a module or distributor pickup coil issue. These parts whenthey fail should leave fault cdes so get them read.
Next, the check engine light will pause shortly followed by the second digit of the trouble code. For example if the check engine light blinks once and pauses followed by six blinks the trouble code number would be 16. If no code is present the check engine light will stay one constantly. To restart code gathering turn the ignition key to the "off" position, wait three minutes and turn the ignition key back "on" again without starting the engine. Remove the jumper wire once code gathering is complete. To clear code after the repairs have been made remove the negative battery cable for one minute and reconnect.
Truck will be running fine, then all of a sudden i - toyota_dianostic_connector.jpg
Toyota Diagnostic Connector
Toyota Code Definition Table
Code 11 Momentary interruption in power supply to ECU (electronic control unit or computer) up to 1991
Code 12 Engine revolution signal missing Code 13 Rpm signal to ecu missing above 1000 rpm
Code 14 Igniter signal to ecu missing
Code 16 A/T control signal missing from ecu
Code 21 Main oxygen sensor signal fault
Code 22 Water temperature sensor circuit fault
Code 23 and 24 Intake air temperature signal fault
Code 25 Air/fuel ratio LEAN
Code 26 Air/fuel ratio RICH
Code 27 Sub-oxygen sensor signal or heater circuit fault
Code 28 No. 2 oxygen sensor/heater signal fault
Code 31 and 32 Air flow meter circuit or Vacuum sensor signal fault Code 34 and 36 Turbo-charging pressure signal fault
Code 35 Altitude compensation sensor signal fault
Code 41 Throttle position circuit fault
Code 42 Vehicle speed sensor circuit
Code 43 No starter signal to the ecu
Code 51 AC signal on; DL contact off (in transmission shifter with diagnostic connector jumped)
Code 52, 53 and 55 Knock sensor fault Code 71 EGR system malfunction
Code 72 Fuel cut solenoid signal fault
Code 78 Fuel pump control signal fault
Code 81, 83, 84 and 85 TCM communication fault
5 Related Answers
SCOTT OCONNOR
  • 169 Answers
  • Posted on Aug 21, 2008
SOURCE: crank no start
SOUNDS LIKE THE CRANK SENSOR POSS. AS I HAVE ONE HERE THAT I JUST DIAGNOSED FOR THE SAME THING WITH A SCAN TOOL WHEN WE FINALLY GOT IT NOT TO START. I'LL FOLLOW UP AFTER SENSOR INSTALL
Anonymous
  • Posted on Oct 06, 2008
SOURCE: truck starts, dies. truck runs good some days,bad the next
I had the same problem with My 1990 F150 300 6cylinder 4x4.....I cahnged all the same things you did, finally I sprayed a can of Gumout through the throttle body and it worked and ran great. Now I add fuel injector cleaner to the gas and a regular clean with the gumout and the problem has'nt come back. Good Luck to you and hope it works!
Anonymous
  • 11 Answers
  • Posted on Nov 22, 2008
SOURCE: 92 Maxima Putters and sometimes even no gas sometimes
Yes I can help you. Change your coolant temperature sensor and all will be well. Only use Nissan, Bosch, or NGK part.
Anonymous
  • 104 Answers
  • Posted on Mar 19, 2009
SOURCE: truck will idle but stalls when i try to give it gas
I do not know what engines yu guys have but this does sound like fuel starvation. Replace the fuel filters and go from there
Good Luck
jimbo647898
  • 21 Answers
  • Posted on Jul 04, 2009
SOURCE: When I start my 2000 GMC Sierra the gear shift
someone has cut the dash off you need to go to the information center and press menu it will give the options to cut it on or off
Truck runs fine then dies while driving then will start back up and run ok.
About 56,700 results (0.76 seconds) Search Results
    GMC Sierra 1500 Questions - Truck suddenly stops running ...
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusJul 11, 2013 - Truck suddenly stops running, acting like it's out of fuel. ... start it and let it run until it dies then check the pressure and shut the key off. ... Was running fine and then turned off as if the ignition was turned of. .... Well mine was a loose battery connection that just shut down the vehicle completely while driving.
    1998 1500 5.2 Shuts Off Randomly - CarGurus
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusAug 29, 2011 - I let it sit for a second then tried to start it back up and it wouldn't start.... 2006 ram 1500 randomly dies while driving 13 answers ... truck started outrunning fine but would randomly die. wait a few ... Used GMC Sierra 1500".
    GMC Sierra 1500 Questions - started stalling and dying ...
    CarGurusJul 28, 2008 - The truck starts and dies. Have to give a little gas to keep running.While driving have to 2 foot it so it won't die. Wants to die when I come to a ...
    Engine Dies and Then Starts Right Back Up
    www.justautorepair.com/chevrolet/blazer/stalls-starts-up
Truck start up run great couple minutes then shut off let set few minutes then crank up run great 30 second shuts down like you cut key off let set few minutes crank right back run fine then dose same
Sounds like it is running out of fuel. Maybe a bad fuel pump, or clogged filter. If it is carbureted, a stuck float valve or clogged float valve might be the problem.
Telling us year, make and model would allow us to help you more.
2answers
Shuts down for no apparent reason
Have you figured out if you are loosing spark or fuel pressure when the engine quits ? Could be a relay, coil, fuel pump, or various other electrical components.
97 lumina, 3.1. Starts runs smooth, drive for 30
I just recently have been fighting the same problem with the same make/model/year vehicle. For myself, I would drive off and on through the day and it would run fine. Then suddenly after a start it would run rough and die. I would have to wait 20 to 60 mins before it would start again. I had it checked and fuel pump was only putting out around 19 psi. It should be around 41 psi. Had fuel pump replaced and no more problems. Furthermore, now it runs so much better. It's funny how over time I didn't notice how the performance was slowly degrading. Unfortunaley fuel pumps for this car run around $300.
1995 Ford Explorer Clutch problem
make sure the fluid level is full- completely- if that isn't it, you may have air in the lines- if the fluid got slightly low, during shifting it can **** air into the line making shifting hard. After you fill up, pump the clutch a few times before you start the truck. hope that's all it is and not the actual clutch going out.
Fuel pump relay
If this happens every time you start your truck and it shuts off the same each time, you just might have a dirty fuel filter only allowing so much gas pass through until it clogs once again. I once had a chevy van, when I would drive it, would go a few miles and engine would shut down.   I would wait 10 or 15 minutes, it would start up and allow me to drive a few more miles then shut down again.  I changed the fuel filter, It was fine after that.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
