I'v'e tried turning it on with and without the charger plugged in to it, the battery was fully charged when it stopped working, and i've tried different batteries.
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $66.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: my olympus fe-330 will not turn on
was just having the same problem the camera would not turn on... NOTHING.... battery fully charged was messing around with it opened battery door pushed in on battery while trying to turn on and it came on, guessing battery was not making complete contact added a piece of foil in door to push down on battery when door shut now working fine
SOURCE: Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the
point the light will turn on, when it starts flashing slide it off then
back on. Do this a few times so it charges a little, then you should be
fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
SOURCE: My FE 340 Olympus Camera tries to turn on, but
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: Hi, how do you take black and white pictures on
you can't shoot in black and white but you can take a picture and change it to black and white.after taking your picture use the color edit option at playback.arrow right or left to choose the picture then press the ok button.use the right and left arows again to select desired color and press the ok button again.this will save a seperate image copy of you original only in black and white.
hope this helps.
