Watts Onan Portable Generator - 5000 , Model# 6500 Logo
Posted on Jun 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On my 9 hp onan genset it runs fine but the 20 amp breaker on makes it shut down is there short or abad breaker
Has two breakers, 30,20. 30 runs ac,all utlets n rv, micro, stove.n more the 20 seems to only run 3 outlets for tv.those outlets r no pwr and when u kick both breakers on runs rough n shuts off? the 30 runs fine. thought maybe shrt in the line or breaker went dead. genset runs rough under load. or voltage reg.email me at brianwaynehoffeld at gmail. com thanx guys
Anonymous
Level 3:
  • Master 5,807 Answers
  • Posted on Jul 30, 2012
Anonymous
Master
Level 3:
Answers
5807
Questions
0
Helped
272212
Points
13914
To determine if it is from the breaker use a
Tong Tester
These would indicate what current is being consumed by the load.
2 Related Answers
Anonymous
  • 26 Answers
  • Posted on Aug 29, 2009
SOURCE: onan genset generator in rv is running but no
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jul 23, 2010
SOURCE: Genset starts and runs fine but the 30 Amp circuit
What about when you have it powering the motorhome, without AC on, does it trip then? Do you have anyone you know with a multimeter and knows how to use it? How about buying a plug in voltage meter at a hardware store as a good start. You simply plug it in to a receptacle in your motorhome and it will tell you the incoming voltage and they are not very expensive. That will help diagnose generator problem.
I have a 2002 HR MOTOR HOME WITH A 7500 QUITE ONAN GENSET THAT WILL NOT RUN BOTH AIR CONDITIONERS WHAT WRONG WITH IT
What happens when you try? breaker trip? shut downs unit? what code flashes on the units start switch? Does the HVAC run ok on shore power? Does it happen when the HVAC runs turns off, then back on in less than 5 mins (high head pressure and locked rotor start current) Please give more details
HOT SPRINGS IQ SPA shutting off sporatically
Could be as simple as turning off "Summer Mode" that should only be used in very hot climates.
Hold both temp buttons (+ -) in until icon on display is gone.
8kw onan genset wont keep running whrn it tries to take on the load, will run forever if i kick the breaker switch to off.
What is the Spec number?
Also can you read a fault code on the start switch?
Do you know how to read the codes and post? if not let me know
Compressor won't sstay running and trip breaker
You gave a lot of information, but you didn't say if it worked when free wheeling. If not, I would suspect the inertia switch. If it is working, you should hear it click when the motor is winding down after being shut off, at least when free wheeling. A 20 amp breaker will certainly handle a 15 FLA motor, even on startup. They don't trip at 20 amps exactly, especially on a simple overload. Even at twice the rated amperage, it can take several minutes to trip it. They will trip quickly on a dead short, however, or a severe overload. I doubt the windings are shorted or it either wouldn't work (start windings) or would run at a slower speed with the inertia switch constantly tripping in and out with it coasting while tripped in (i.e., accelerate, coast, accelerate, coast, etc.)
Genset starts and runs fine but the 30 Amp circuit breaker trips as soon as a load (AC) is applied. Started right up, ran half a day, but now when it starts the minutes I click on the ac the circuit...
1helpful
Onan genset generator in rv is running but no power to rv...circuit breaker has been checked and main breaker in rv has been checked still no power
I have an onan 2800 gen that will not charge
If the govenor didn't work that means that you placed the linkage on the carberator the wrong way. This will cause the genset to overspeed and possibly stop the genset from creating voltage. If the genset does not create voltage then you won't have a charger. Fix the linkage first by looking to make sure that the throttle plate is closed before starting genset. Once you start the genset check for voltage.
Upsizing breakers
In short - NO. 15 amp circuits are intended for lighting and outlets and usually have 14 gauge wiring. A 20 amp circuit is usually wired with heavier 12 gauge wire which can carry the increased amps. If you plug in a 20 amp breaker into a 15 amp circuit you run the risk of overheating the smaller gauge wire and starting a fire.
1helpful
Dryer and breaker
you have a week breaker or a breaker that is to small you need a 40 amp breaker 20 on each side (two breakers locked into one) or worse you have a short in the dryer. If dryer runs for a little bit and then shuts down its the breaker.if it throws breaker as soon as you plug it in or start it then the short is in your dryer good luck
Top Watts Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
