SOURCE: 2000 Nissan Quest, Hot air is coming out vents no
It is most likely the temp door actuator motor in the dash the dash has to be removed to repair the problem.
Testimonial: "This let me know I was the right track. My Ch---- Manual give no troubleshooting "
SOURCE: Front air condition does not blow cold. Rear air condition does
sounds like a damper door in the front not working properly, these are actuated by the front temp control, the door is operated by either a manual cable, and electric actuator, or vacuum. I hope this helps you zero in on your problem. Merry Christmas
SOURCE: I have a 2005 Nissan quest and I'm getting a p0507
No..you can't adjust the idle...
Possible cause---Electric throttle control actuator, intake air leak or PVC system...check these 3 things...
SOURCE: 2005 Nissan Altima 2.5s 4 cylinder. 1) When
no it could be air condition clutch that engage/disengage the air condition compressor and disengage it through the pulley or could be the pulley bearings one of them . also check the solenoid that controls that clutch .
have a good luck sir .
SOURCE: 2008 Nissan Quest - AC
Check and see if your cooling fans are working. At least one should come on at all times when the a/c is turned on.
Yes.....
