Sony RDR-VX530 DVD Recorder/VCR Logo
Question about Sony RDR-VX530 DVD Recorder/VCR
Vhs is stuck in machine. Won't play and won't eject.
Posted by KathyB on
Anonymous
  • Sony Master
  • 6,771 Answers
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Posted on Jun 28, 2012
1 Related Answer
gopakumarg43
  • 76851 Answers
SOURCE: Sony RDR-VX525 VCR / DVD
Hello
It has a switched mode power supply [SMPS] regulator inside it. You have located the fuse in itself. As far as fuse is OK, either switching device or mains rectifier diodes and load ressistor should be checked. There is no direct short circuit inside that board, if so fuse will fire up. It is very difficult to an unexperienced person, who is not have sound knoledge in digital elctronics; to rectify this problem. If you are experiecied, go forward. If not, it will be best to replace the power control board. It is available on most of the electronic component spare part shops at your town. There is a number printed on its printed circuit board and it should be noted. The number must be the exact one, if you replace the board. Take out the board from the set, and keep it with you as a sample, when you go to buy a new one. If you are not confidence in this work, never do nothing, and get it repaired by any experienced service personal. OK.
Posted on May 31, 2011
VCR won't eject tape
unplug VCR take the top off about 4 screws or more I would say you willmbe able to see that tape is wound round inside you should be able to remove it .
1helpful
My VHS tape is stuck and won't eject or plsy
The transport mechanism ff/rewinds and drives the tape back into the cassette when eject is used.
Most likely a bad belt or the drive idler wheel (rubber or geared). Unit would have to be taken apart to "see" what is not happening.
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
2helpful
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
My Ford Explorer 6 disc cd has 1 cd stuck in it and it won't eject, play or let me load other cd's. How do I get the cd out?
take the radio out and take it apart and move the sensor out of the way and take the CD out you might have to replace the CD sensor
1helpful
2answers
VHS tape won't eject
Hello
Check for any borken drive belt in the mechanism.
Cd stuck in 2004 VW Beetle
Soo easy just keep playing with it keep pressing the button the same thing happend with my mom and i got it out the way i told you.,DO IT WHEN YOU CAN!! :)
I have a ION VCR2PC and the power button won't stop blinking. Also when I put a VHS tape in, it turns itself on and then right off again and ejects my tape. There is not anything stuck in the ION...
If the take up spool is not turning properly it is not uncommon for the machine to eject the tape and turn off. Check the drive to that spool and correct.
2answers
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
