Heat works but the rotating drum remains stationary. Just stopped working suddenly last night.
SOURCE: drum not turning
remove panels to gain access to the drum belt and replace it. usually less than $10 repair for do-it-yourself.
SOURCE: No heat on Whirlpool leq8000jq1. Is it just the heating element?
There are several things that could cause this problem, here are a few common things it could be, before doing any checks you should always make sure you disconnect your appliance from it's power source.
SOURCE: No heat
either you have lost one leg of input power for the 240volts or the neutral connection is open or the element is defective
SOURCE: I have a whirlpool duet dryer and I can feel the
I had a similar problem with my dryer, if the heatin element is workin but the drum itself isn't turning it is probably a broken belt i the back, it is usually an easy fix and if you have a warranty on your dryer then you could call the maintance and they can fix it fir you covered under you warranty, if not you can usually find the belt at most hardware or appliance shops, and fix it yourself easily. It is located in the panel at the back of your dryer. Hope this helps you some
