Cars & Trucks Logo
Valerie Posted on Jun 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2003 GMC 2500HD Duramax, truck will not start, bought a new battery, truck will not even click over. Listen for fuel pump and it's working. What else is wrong?
A couple of days ago, it had to be jumped, this morning it was completely dead. Bought a new battery today, and still nothing. Not even a clicking. What else do I check or what else can it be?
Steve Jensen
Level 3:
  • Master 417 Answers
  • Posted on Jun 28, 2012
Steve Jensen
Master
Level 3:
Answers
417
Questions
Helped
365200
Points
1133
The only thing I can think that it would probably be is the ignition. Not where you put your key but the box with all the wires going to it under your steering column. Hope this helps. good luck
5 Related Answers
Anonymous
  • 56 Answers
  • Posted on Jan 05, 2009
SOURCE: 2003 GMC Duramax Diesel won't start
I see that you had the injectors replaced 20,000 miles ago. I would still check the oil to make sure it is not overfull. The new injectors could be bad. If the oil level is not overfull then get a paper towel and touch the dip stick tip on the paper towel while oil is on the dip stick. If it's only oil it will not spread. If it has diesel in the oil the oil with spread. If this test doesn't show the injectors to be bad then you have three other possibilities. The FICM (fuel injection control module), the fuel pressure regulator, or the injection pump. It's hard to pinpoint what the problem is without running more tests and the only way to run those tests is with the computer the dealership has. Just so you know your injectors are still under warranty until 100,000 miles. Most likely you will have to take it to the dealership to get you truck fixed. I hope this helps you some.
countrysi248
Jerry Koski
  • 443 Answers
  • Posted on May 22, 2009
SOURCE: My 2004 2500HD Duramax won't start. Acts like the
welcome anytime .. I have a duramax also 06 4500 and so far I love mine its been trouble free at 58k miles now.. good luck Jerry
Anonymous
  • 54 Answers
  • Posted on Jun 29, 2009
SOURCE: my 2008 nissan frontier truck is dead
Charge the battery if the truck starts its fixed if not i would have the alternator checked. if the truck is under warranty which it should be i would have it towed and checked by nissan
metroice
steven beasley
  • 105 Answers
  • Posted on Sep 12, 2009
SOURCE: I have a 2002 chevy blazer LS with a 4.3 Vortech
have your starter checked, the solenoid may have gone bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Sean80000
Sean Piquet
  • 1867 Answers
  • Posted on Nov 30, 2009
SOURCE: 87 f250 drained brand new battery
I would first have the alternator checked by an auto electrician to ensure it is working correctly and is providing the correct volume of current. It may be faulty and when driving you will be drawing battery power instead of power from the alternator to run the electrics. This will drain the battery.
Alternators do not last forever and if you are still running the original unit it is likely to be on it's last legs and you will need a replacement unit.
Where is the fuel pump located on a 2001 gmc 6.6 turbo duramax deisel truck?
Hi Lone Ranger,
The first link offered has information to set you up US Diesel Parts Fuel Pumps Injection Pumps and Injectors GM Duramax LB7 . Now on to the location. Here is a quick feed to watch duramax cp3 pump swap . Lets finish with this gentleman's input and contribution. Duramax cp3 high presure fuel pump removal .
This will provide a look and see distant generalization of what you may be getting into and some live experiences of those who did. Fare. Well.
Water pump on 2003 duramax Sierra Diesel truck
if the leaks are not evident in the engine bay , it could be the heater in the cabin
My 2500 duramax diesel dosent want to start
Does it have diesel?
Could be fuel filter or fuel pump.
Glow plugs?
Injectors? these trucks have been known to have bad injectors.
Possibly the oil pump, the injectors run off the oil pump.
9helpful
3answers
2003 Duramax Diesel loosing prime and will not start until I lift the hood and pump the prime plunger on the fuel filter housing.
duramax diesel trucks do not have a lift pump. start with the simple things make sure your fuel filter is tight and check the shreader vlave on the fuel rail if that don't help check the filter housing for a leaks arround the heater element or a crack in the housing itself
1helpful
My 2003 gmc 2500hd will not start. the battery is
check that the oil level is full and check to see if the low oil pressure switch has fallen off it's between the engine and firewall just below the distributor, als tun the ingtion key on and listen to see if you here the fuel pump come on for two seconds, if it does check fuel filter. if it does not check fuel pump relay and blowout prevention valve reset it if it's not allowing fuel to flow will bwe on same side of fill hose tank.
2001, Duramax Deisel 6.6 won't "restart"
fuel pump is obviouslynot working !
check it & its wiring!!!!!
12helpful
2answers
RFA battery low. What does this mean
Check you Key FOB for a low battery.
8helpful
2answers
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
