Question about Whirlpool RBS305PDS Electric Single Oven
Can not raise temperature above 350
When I start the oven it goes to 350. If I try to adjust it higher. It goes down. Even if when I am pushing the increase temp button it goes down. It works fine it just won`t go above 350.
Posted by micbare on
  • micbare
    micbare Jun 28, 2012
    When you hit the bake button. It always starts at 350. Then you adjust the temp up or down . But now it goes down when you push the increase button. It goes down as it should when you push the decrease button. Once it is down the only way you can make it go up. Is turn it off and start over.
Megan W
    Dedicated:
    Visited the website for 20 consecutive days.
  • Whirlpool Expert
  • 84 Answers
If the Whirlpool oven bakes great at 350 degrees, then the problem your having is with the membrane circuitry = The touchpad/keypad on your oven is faulty. The buttons itself is bad.
You can read more about this issue here -- http://blog.fixyourboard.com/2015/08/18/whirlpool-oven-wont-increase-temperature-up-arrow-decreases-temperature-e1-f2-error/
Replacement touchpads are available for your unit through FixYourBoard.com
Whirlpool Models that normally experience this issue below -- GBS277PDB0, GBS277PDB1, GBS277PDQ0, GBS277PDQ1, GBS277PDS1, GBS307PDB0, GBS307PDB1, GBS307PDQ0, GBS307PDQ1, GBS307PDS1, GBS307PDT1, RBS245PDB1, RBS245PDB2, RBS245PDB4, RBS245PDB6, RBS245PDQ1, RBS245PDQ2, RBS245PDQ4, RBS245PDQ6, RBS248PDB4, RBS248PDQ4, RBS275PDB1, RBS275PDB2, RBS275PDB4, RBS275PDB6, RBS275PDQ1, RBS275PDQ2, RBS275PDQ4, RBS275PDQ6, RBS277PDB1, RBS277PDB2, RBS277PDB4, RBS277PDQ1, RBS277PDQ2, RBS277PDQ4, RBS305PDB1, RBS305PDB2, RBS305PDB4, RBS305PDB6, RBS305PDQ1, RBS305PDQ2, RBS305PDQ4, RBS305PDQ6, RBS305PDZ1, RBS305PDZ2, RBS305PDZ4, RBS305PDZ6, RBS307PDB1, RBS307PDB2, RBS307PDB4, RBS307PDQ1, RBS307PDQ2, RBS307PDQ4, RS675PXEB0, RS675PXEB2, RS675PXEQ0, RS675PXEQ2, RS675PXEZ0, RS675PXEZ2, RS675PXGB0, RS675PXGQ0, RS675PXGZ0, RS676PXEQ0, RS676PXEZ0, RS696PXEB0, RS696PXEB2, RS696PXEQ0, RS696PXEQ2, RS696PXGB0, RS696PXGB2, RS696PXGQ0, RS696PXGQ2 Whirlpool Oven Wont Increase Temperature Stuck at 350
Posted on May 05, 2017
Stephen
    Top Expert:
  • 21,873 Answers
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Posted on Jun 28, 2012
5 Related Answers
Anonymous
SOURCE: Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
Posted on Jan 08, 2011
Amigaman
Gerald Griffin
  • 248 Answers
SOURCE: Oven does not maintain temperature while cooking.
Is this a gas unit? If so you might have a weak oven igniter.
Posted on Nov 24, 2007
Carmen Mikulic
  • 415 Answers
SOURCE: Whirlpool Oven temp control will only go down ,will not go up
hi there,
here is a couple of things to take a look at:
please check the keypad ribbon cable and make sure it's seated corectly into the control board
also check the button itself and see if you can see if it's depressed or warped in any way
let me know if i can be of more help.
thanks
Posted on Sep 25, 2008
Anonymous
SOURCE: Oven model RBS245pd86
after cleaning the oven the bake temp would not go any higher than 350. when you press the temp button to go lower or higher it only go down. could you tell me what is wrong or what to do.
Posted on Sep 30, 2008
dennis dodge
  • 1891 Answers
SOURCE: My clock display is faded, oven works, no temp readings
the e o c ( the clock) is at fault . and the diag is correct . most parts today only cary 3o days .. hope the hepled . mm
Posted on Jul 15, 2010
Testimonial: "Thanks for the confirmation! I have been on vacation and need to get back on to it! "
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Nov 26, 2014 | Whirlpool Ovens
When I light my oven, it stays on full all the time. Is it the thermostate
I'd recommend buying an oven temp dial to stick in your oven to verify the actual temp. Then you can turn on the oven using a lower setting and write down the temp for the setting. Then as you slowly adjust the setting higher and higher, note each temp. If it doesn't show a consistent increase of temp for each setting, you may need it calibrated or replaced. Good luck!
Sep 18, 2014 | Ovens
I dont know how to use the oven properly. when i need to bake or roast something i want to put in my own temperature, but there is no option for me to do that. when i turn on the stove all i have is the...
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Gene
Aug 04, 2011 | KitchenAid KEHU309 Stainless Steel Dual...
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
[email protected]
May 27, 2017 | Whirlpool Ovens
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Jul 27, 2008 | Whirlpool RBS245PDS Electric Single Oven
RBS305PDB6
The 350 as you stated is a default set point that you see before you start the cycle. What you should see afterwards (start bake) is the current temperature - which would normally be lower than the set or desired temperature - it will eventually get there
Regards
Jul 19, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RBS305PDS Electric Single Oven Logo
3,961 people viewed this question
Top Whirlpool Ovens Experts
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
