Black scrine
SOURCE: My Acer aspire one za3 will not turn on at all.
Either you have a bad ac adapter(powercord) or the power jack where you plug it in on the laptop is bad.The power board where the button you push is located could also be bad.Start with trying another ac adapter first.
Posted on Jul 06, 2010
SOURCE: acer aspire 1640z bios update
That's a memory or RAM error. You need to re-seat the ram of your machine.
Posted on Jan 14, 2009
SOURCE: RECOVERY BIOS OF ACER ASPIRE 1640Z
Ok what you need to do is unsolder you old bios chip and solder in a new one!
Posted on May 05, 2009
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Posted on Dec 21, 2009
SOURCE: aspire one model za3 user guide
Hello, your laptop is known as the Acer Aspire One 110, here is a direct link to the laptop from Acer. at the bottom of the screen you see a drop down menu for Technical Documentation, though I think Acer only have them in German? :-s
Posted on Jan 04, 2010
Dec 23, 2013 | Acer Aspire One PC Notebook
Oct 01, 2013 | Computers & Internet
Aug 12, 2013 | Acer Aspire Computers & Internet
Feb 25, 2013 | Acer Aspire One PC Notebook
Jul 06, 2010 | Acer Computers & Internet
Feb 24, 2010 | Computers & Internet
Jan 04, 2010 | Acer Aspire One AOA110-1113 Netbook
Oct 11, 2009 | Acer Aspire 3000 Notebook
Jul 08, 2011 | Acer Aspire One AOD150-1920 Netbook
Feb 28, 2017 | Acer Aspire One AOD150-1920 Netbook
587 people viewed this question
