Apple iPod Photo MP3 Player Logo
Question about Apple iPod Photo MP3 Player
My ipod won't play music
No sound
Posted by amandamilani on
Anonymous
    Sergeant:
    Champion:
  • 268 Answers
Are you sure the music format is right ?
Posted on Jun 28, 2012
3 Related Answers
Anonymous
  • 35 Answers
SOURCE: ipod nano 8g
Did you place the music on your iPod via iTunes, or just drag and drop to the device?
The music must be added through iTunes, or the iPod will just act as an external hard drive--storing your music, but you can't play it.
If you just dragged and dropped, take it off your iPod, start up iTunes, then add the music that way.
Posted on Nov 15, 2007
Anonymous
  • 4402 Answers
SOURCE: ipod
headphone jack bad?
Posted on Jan 22, 2008
Anonymous
  • 25 Answers
SOURCE: Ipod wont play music / No sound
The clicker noise you hear is separate from the audio output functionality of the iPod. It sounds like an issue with the headphone jack possibly. Try a soft reset by pressing the menu and center buttons at the same time for 5-7 seconds.
If that does not work, then please consider the FREE Diagnostic Testing that we offer through our website. It will cost you virtually nothing to have us diagnose your issue. Our company is staffed with formed Apple Techs and we are an Accredited Business with the Southern Colorado Better Business Bureau (BBB).
Regards,
Rick
EverGreen Electronics
'Eco-Friendly iPod Service, Sales & Recycling'
E-Mail: [email protected]
Website: http://www.EverGreenElectronics.com
FREE Apple iPod Technical Support - http://www.iRepairGuide.com
Posted on Jun 11, 2008
I have an lg home cinema and docking station GT462DZ . Sometimes, when i try to dock my ipod touch in it , it says 'check ipod' and it won't play music . It won't work. I always restart my...
It could be that some dust or something has got inside the dock and giving a bad connection. Check both devices for damage to the dock connections.
I can't hear sound/music from my IPod. I've tried plugging it in the iPod cable an USB cable. The screen shows that it's playing but I can't hear anything
Make sure your volume is turned up on your ipod and in the car make sure nothing else is playing. Also check your instruction book and if all fails take your car back to where you bought it from and explain what has happened also make sure it's properly pluged in!
3helpful
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
My jensen vm9214 will play my music from my ipod but it will not show a display of the song or anything and when I click pause or play or fast forward on the screen it doea not do it so I have to play and...
First off, is the unit equiped as ipod ready or are you using an auxillary input. If your unit is ipod ready, this means it has the ipod cable to the unit. If you are using an auxillary input, it won't show the name and yes you will have to control your music from the ipod itself. Just some things to think about. If your unit is malfunctioning, I recommend visiting the local stereo shop.
2helpful
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
1helpful
I will try and make this as short as possible and hope you understand what I am asking. I just got an Ipod Classic last month and signed up with Itunes and then downloaded about 1300 songs from my cd...
You can't "backwards sync" (put music from your iPod back onto your computer) through iTunes. When you went to sync after you got your fixed computer back, I'm assuming iTunes tried to copy what was in iTunes (nothing) to your iPod, which probably is what caused these problems.
Assuming you still have the music on your iPod, I would recommend transferring the music from your iPod back to your computer (to a folder other than iTunes), restoring your iPod to factory settings, then moving all of the music files into iTunes and re-syncing your iPod.
There are two programs that are available to transfer songs from your iPod back onto your computer. The first is iDump and the second is YamiPod. I have found that iDump is the better of the two.
The link for iDump is:
iDump
Hope this helps!
1helpful
2answers
I have the ICF-CS10iP dream machine my ipod (which is a 2nd generation touch) will charge but wont play music what is wrong it use to beable to
This happened to me - the radio also wasn't playing. I was able to resolve it by resetting the unit using the instructions in this manual: https://docs.sony.com/release/ICFCS10IP.pdf
I hope that helps!
Top Apple Audio Players & Recorders Experts
woodzowl307
Marvin
Marvin
W.L.
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
