I can't access my external hard drive Western Digital element 320GB so i did chkdsk h:(drive letter) it did chek disk.now when i access it says data error(cyclic redundancy check) i have more than 300GB data in it please help to access it
I noticed you ran the chkdsk utility on this drive did you try to repair bad sectors or just files click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive I found that you get best results by ticking one box then returning after it has finished then tick the other box if still no joy hope this helps
try to use the external hard drive in a different computer and check whether you are able to access the data that is present on the external hard drive or you can try to connect it to a different port and check
SOURCE: F: is not accessible. Data Error (Cyclic
registry may be corrupt...
get Tuneup Utility from my site and install it...
www.sureshayyar.110mb.com Download Page
run TU clean the registry in disk and try
SOURCE: 500 MB data
1. this ( cyclic redundancy check) is the computers way of saying " i don't recognize the data check-sum.
2. This issue could be due to the data controller on the USB drive being defective.
3. try purchasing a new case with a new controller board.
4. Check to see if your 1TB USB drive is compatible with your pc.
