SOURCE: Roller marks on photos when printing
This printer is laser based so the toner is heated onto the page. It could be the transfer roller that is dirty. The transfer roller can be found on the door when you open the printer. It is the thin roller at the bottom. Check and see if there is a build up on it or if there is a repeating line on the larger transfer assembly which is also on the door. You can try rubbing them of with a dry lint free cloth. It may be that you need to replace it.
SOURCE: toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
SOURCE: Color Laser Jet 3800 leaving roller marks on paper
Pull out the fuser at the rear of the machine.
SOURCE: Kyrocera 4000DN
There is a huge problem with the charge rollers in the drum units, but they can't be bought seperatelly. You should have a 3 year warranty on the drum unit.
SOURCE: Black roller marks on right side of paper
Sounds like you have a bad fuser assembly if the drum unit didn't solve the probelm.
