Numbers on PCB: WBS-155TD
Go to this page it will take you to a "dropdown" menu. Go to your model number and there will be 2 different PCBs in each category. One is for the door the other is the main. make sure you get the right one....match up the numbers you mentioned 155TD in yours which is the "pren" version of the 2 choices. Hope this helps you! http://mcappliance.com/partorder.aspx
J
SOURCE: MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
SOURCE: Magic Chef Wine Cooler Model MCWC44DZ Where can I
On the Magic Chef site you can order parts for the cooler. I took mine out and treid to find them on the web somewhere else and could not locate them anywhere except China and England. I know this isn't true but tried every search option I could think of. They are about $22 plus shipping (HIGH). You might try the following: http://www.fixya.com/support/t1814377-magic_chef_mcwc44dz_e4_error
